Old 12-15-2015, 08:54 AM   #1
helotes , Texas
Help with AC
Happy Holidays to all,
My 2006 25' FB has the LS package. I believe that package includes a 13500 BTU AC/heat pump unit as part of the package (not absolutely sure however). I live in south Texas and often camp in very warm weather. My AC just manages to keep my trailer livable during the day but takes a long time to get there. I was thinking about taking advantage of some off season sales and upgrading to a 15000 btu unit. I think I want to stay with a Domestic but could be swayed. There's a couple of models that sound like they might fit the bill. I was wondering if anyone has experience regarding retro fitting the larger unit into where a 13500 btu (or possibly smaller) unit used to be. Also hoping to find a unit that's quieter. I'm kind of wide open and looking for advice.
aldamiani is offline   Reply With Quote
Old 12-15-2015, 09:03 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
There is no difference in the mounting.....it mounts quick and easy. Your best bet is keep what you have and invest in awnings and window shading.
Old 12-15-2015, 10:55 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Is the top of your unit painted white? If not consider painting it.
If you were to design a trailer for the poorest possible thermal considerations it would be an Airstream.
There are 2 functions to an AC, temperature reduction and humidity reduction. If you size an AC, larger, for temperature reduction it will short cycle and never reduce humidity.
2004 Excursion 4x4
Old 12-15-2015, 11:01 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
"Painted"... Actually "coated" my roof. The AC now CYCLES.... Also stays warmer in winter!
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 12-16-2015, 01:27 PM   #5
helotes , Texas
The top of my trailer is painted white already, otherwise I would certainly paint it. I've learned a lot the last few days. One of the things I read is that you can run a 13500 BTU AC on a generator. Apparently you need shore power to run a 15000 BTU unit. It doesn't come up too often, but being able to run my AC on generator power has come in handy a couple of times. Thank you all for your advise. Have a happy and safe holiday season.
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
