Old 09-20-2016, 09:51 AM   #1
2007 30' Classic S/O
durango , Colorado
Exclamation Help!! Where is fuse for my hitch power jack?
It seams I have blown a fuse for my trailer hitch jack. No power to jack or light on jack. Is there a fuse that may have blown? Where would it be located on my 2007 Airstream Classic? Thanks.
jimmymac is offline   Reply With Quote
Old 09-20-2016, 10:02 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If its like my 2008 Classic, trace the wire from the jack, I assume its a Superjack. If you don't see it by the frame then it's likely buried in the cable sheath that runs up into the trailer subfloor. I can't find mine from the outside either. Not a convenient place at all. My jack terminates to the positive bus inside the trailer. You may have to disconnect it from the bus and pull it back from the outside a little bit to expose it. Its in a plastic bulb on the wire. Replace it then pull it back into the trailer and reconnect.
When I replaced my Superjack with an Atwood I used a butt connector and electrician tape to connect to the same wire. Luckily my fuse has not blown.
Kelvin
Old 09-20-2016, 10:06 AM   #3
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
It is located under the A frame, if you follow the wires from the motor. Newer models, moved it up by the motor where you can see it and replace easily. I went through same "panic" when we had our 2006 Safari, and while I was "panicking" trying to purchase a new motor at the AS dealer outside Austin, my wife crawled under the unit A frame, figured out where it was, and called me to buy a fuse instead of a motor! Saved me some money and stress for sure...now I always carry 10 of those little buggers from Amazon, since even the newer models can blow when you stress the motor., which still happens when I flip the switch the wrong way.. (but, it only happens every "now and then"!) LoL
Old 09-20-2016, 10:22 AM   #4
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Power jack fuses (photo, specs, location, discussion)
(On the 2007 23' Safari)
Welcome to AirForums jimmymac!
SilverGate is offline   Reply With Quote
Old 09-20-2016, 10:30 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine is located right on the side of the jack in the power line. 30 amp slow blow available from NAPA.
MICHAEL
Old 09-20-2016, 12:02 PM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have had 2 different brand trailers with 2 different brand jacks.
The fuse was in the same location on both- in the hot wire to the battery just inside the a-frame on the driver's side.
I just installed a new Super Jack and put the fuse in approximately the same location.
The fuse holder is originally yellow, but Airstream paints them that dark charcoal/black color when they paint the trailer frame. I have a yellow one again.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-20-2016, 12:17 PM   #7
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
I've got a question for all out there that blow the fuse on your jack. Do you run it until it bottoms out when you retract it or extend it fully out? Knock on wood, I've got an 86 with the original jack and have yet to blow a fuse. I never run it to the limits on extension or retraction.
Streamracer is offline   Reply With Quote
Old 09-20-2016, 12:32 PM   #8
m.hony's Avatar
2013 30' Classic
My fuse blowing started after I bent the jack post...
New jack now.
True. If you are blowing fuses there may be a problem...
TAC #MS-10
Airforums #70955
Old 09-20-2016, 12:39 PM   #9
1991 25' Excella
From everyone's post, thinking I need to find that fuse on my -new-to-me 91 Excella since the power jack is nonlt responsive. I did buy a new jack but if the fuse is the issue then I can save the new jack for later.
Oh, Hello gypsydad - I'm in NW Austin
slbsto is offline   Reply With Quote
Old 09-20-2016, 01:28 PM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I don't care about how to find and replace fuses, how did you (gypsydad) get your wife to crawl under your trailer?
GammaDog is offline   Reply With Quote
Old 09-21-2016, 11:49 AM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
And what the Heck is "cowbell"?
MelGoddard is offline   Reply With Quote
Old 09-21-2016, 12:10 PM   #12
m.hony's Avatar
2013 30' Classic
I assume Chief is a MSU fan?
TAC #MS-10
Airforums #70955
Old 09-21-2016, 01:34 PM   #13
SilverGate's Avatar
2007 23' Safari SE
"Guess what... I got a fever... and the only prescription... is more cowbell."
More Cowbell
Old 09-21-2016, 01:44 PM   #14
gypsydad's Avatar
Good question; she is quite tenacious when it comes to troubleshooting things, that cost $$! I typically just go for replacement; she try's to save us money!
Fuse for power jack minddr Towing, Tow Vehicles & Hitches 28 06-27-2017 10:20 AM
Barker High-Power Jack Blows Fuse While Driving Woodguyco Jacks, Stabilizers, Lifting and Leveling 23 09-19-2015 10:15 PM
Blowing fuse on Power jack. StreamRollin Electrical - Systems, Generators, Batteries & Solar 36 07-19-2015 11:10 PM
Help please re power jack fuse/breaker AFUser Electrical - Systems, Generators, Batteries & Solar 4 06-11-2014 07:28 AM
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 11:38 AM
