Old 06-28-2012, 08:06 AM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Help!! What is this
Hello all,
I opened the door this morning to keep it cool today and noticed this red stuff on the door. Nothing will clean it. Has the sun done this if so what kind of primer and paint should I use to freshen it up. Sorry I didn't flip the pic
bertro is offline   Reply With Quote
Old 06-28-2012, 08:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Give us a bit more info. Is this on the door, inside or outside?
What should the orientation of the picture be. Did this just happen in short order. Dose it appear any place else in or on the trailer.
2004 Excursion 4x4
Old 06-28-2012, 08:49 AM   #3
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Door
This is the interior of the door and it should be turned 90 deg. right. It does not appear to be anywhere else in the interior. There has been no moisture between the screen door and door. I seemed to happen quickly.
Old 06-28-2012, 09:01 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Assuming it's essentially the same stuff as the vinyl coating on my interior skins, it's quite tough and I've found that all sorts of weird-looking marks I thought were permanent stains come out with the right coercion. Simple green and terrycloth rags have cleaned quite a bit from mine. I've never resorted to anything like a "magic erase" in the Argosy, but that might be an option if strong cleaner doesn't work.
David
Old 06-28-2012, 09:42 AM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
scrubbing bubbles bath cleaner works great on the inside of AS. It cleaned just about everything on mine.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-28-2012, 10:19 AM   #6
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
To me it looks like red primer that would formerly be under the top coat of paint...try rubbing the surface nearby and see if that is it. If that is what it is then you would need to re spray or coat the top coat again. But to me that looks like red metal primer from underneath.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-28-2012, 10:46 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Hey bertro - how you been.
Looks like it may be mold. Have to be careful what you use on the vinyl but here's a couple links of interest:
http://www.airforums.com/forums/f39/...ior-11794.html
How to Get Rid of Red Mold | eHow.com
http://www.homedepot.com/webapp/wcs/...specifications
