Old 01-24-2010, 08:29 PM   #1
1976 31' Sovereign
portland , Oregon
Help! Too large to get through door....
Hi folks!
Here's one for you, I have a stove and fridge that I need to get into my AS, but they're too big to get in through the door...
Anyone ever cut out the floor or some other way? (Take off the skin??).
I may be grasping at straws here...
V.
mrsdinapoli is offline   Reply With Quote
Old 01-24-2010, 08:34 PM   #2
Originally Posted by mrsdinapoli View Post
Hi folks!
V.
Sounds like your wanting to install some home type appliances.
If your going to install a home type gas stove in the trailer, please understand that it will not work the same as it did in a home.
Natural gas appliances must have the orifices changed if you want them to correctly work on LPG.
Old 01-24-2010, 08:37 PM   #3
Hi folks!
V.
Cutting the door frame and/or removing some inside and outside metal, is a task that while not impossible, is very difficult to pull off.
If you cut the door area, it's doubtful that the door would ever work properly again.
What is it your trying to accomplish??
Old 01-24-2010, 08:40 PM   #4
ltenbrink's Avatar
1968 30' Sovereign
Lorton , Virginia
Oh my!
ltenbrink is offline   Reply With Quote
Old 01-24-2010, 08:42 PM   #5
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
measurements
Could you give a few more details? How big is the door to your trailer? What are the dimensions of the fridge? Is it possible to take the door of the fridge off of its hinges and get it in there sideways? Back window might also be another way to get it in. Is it an RV fridge or are we talking about a residential type fridge? Pictures would be very helpful.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 01-24-2010, 08:55 PM   #6
tallytwo1994's Avatar
tallahassee , Florida
Yes, windows can be removed. Of course check the measurements first to make sure it will fit. If not, return them or put them up for sale.
Carol
tallytwo1994 is offline   Reply With Quote
Old 01-24-2010, 09:13 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The easiest way....get the proper replacements.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 01-24-2010, 09:15 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Every single item of furniture, cabinetry or appliance you see in an Airstream came in through the door. Thus, most RV industry replacement appliances would be able to enter the same way.
Installing non-RV appliances? Even if intending to use for plug-in camping only, watch weights of your appliances. Pay attention to side to side balance, fore and aft location (keep close to or forward of the axles), and the trailer payload capacity. There are a number of ways to discuss roadworthiness of any such arrangment. You wouldn't have to concern yourself with that so much if you were planning on a fixed site camper or poolside cabana. You aren't saying that you are interested in a commercial business inside an Airstream.
Re-purposed home appliances can be had cheaply. Competent disassembly of an Airstream to install affordable appliances can end up costing more than buying real RV appliances.
See where this goes? Too many directions... We need more data, please.
5 meter Langford Nahanni
Old 01-24-2010, 10:30 PM   #9
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Time for a shell off renovation
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 01-24-2010, 10:39 PM   #10
2009 25' SS International
Pasadena , California
an airstream convertible
flmgrip is offline   Reply With Quote
Old 01-24-2010, 11:20 PM   #11
Shell-off isn't far from the truth! Those had better be a long lasting fridge & stove! Here at the forum we have seen some larger-than-dorm fridges installed when a Dometic poops out. I'm thinking on the order of 10-12 cu ft or so. They weren't large. But this does mess with the value of an Airstream. You're going to lose the difference when you sell. Might as well put $$ into it and appreciate the value of good equipment yourself. An Airstream doesn't have the 24' counter depths that match up with domestic appliances.
I started affirming the shell-off idea. The distance between the ribs (rivet lines) is roughly equal to the width of the door. The door is designed to fit within the average rib spacing. So you really can't go in through the wall any better than you could the door.
Old 01-25-2010, 12:42 AM   #12
_
is this the same trailer that's already had the floor removed with a saws all...
and is being used as a uhaul?
http://www.airforums.com/forums/f42/...-ca-60449.html
just cut the rear end open, like a loaf of bread and roll in the booty !
happy travels
2air'
Old 01-25-2010, 10:02 AM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
Perhaps the poster intends only to transport them rather than install them.
Old 01-25-2010, 02:29 PM   #14
1976 31' Sovereign
portland , Oregon
Wab, we're 99% there, so why don't we go all the way, eh? You might have called my bluff. Although, convertible sounds chic.
Sorry, I'm not giving enough background.
It's not RV equipment, it's commercial. It's been retooled for propane. My husband is a professional chef, I know it sounds like we're trying to meld loves that should never meet.
Thanks all for humoring me, I thought I'd stump everyone but the suggestions have been brilliant thus far!
door size
large vent mitsy Roof 5 11-22-2009 02:55 AM
Trailer too Large? TV too small? pixiehat Tow Vehicles 45 03-13-2009 09:36 AM
Looking for a large gutted A/S kdenault Our Community 5 05-11-2006 10:44 AM
proper bulb for large door light? IPM General Motorhome Topics 3 03-19-2006 06:27 AM
A Large Family Janets Husband Our Community 15 02-25-2004 08:53 AM
