Old 01-25-2010, 02:31 PM   #15
1976 31' Sovereign
portland , Oregon
Originally Posted by 2airishuman View Post
is this the same trailer that's already had the floor removed with a saws all...
and is being used as a uhaul?
http://www.airforums.com/forums/f42/...-ca-60449.html
just cut the rear end open, like a loaf of bread and roll in the booty !
happy travels
2air'
Yes! We were just going to take the whole thing down to California and work on it there (sun vs. rain), but ultimately they were going to be used in the Airstream.
mrsdinapoli is offline   Reply With Quote
Old 01-25-2010, 02:42 PM   #16
1976 31' Sovereign
portland , Oregon
Originally Posted by CanoeStream View Post
But this does mess with the value of an Airstream. You're going to lose the difference when you sell. Might as well put $$ into it and appreciate the value of good equipment yourself.
The re-sell value is less relevant in our case. The interior was irretrievable, and we wanted absolute surety that there was no mold, or freeloading rodents/bugs then original interior can afford.
An Airstream doesn't have the 24' counter depths that match up with domestic appliances.
We're working with a blank slate because we are not confined to the original layout. However, that's a very good point.
I started affirming the shell-off idea. The distance between the ribs (rivet lines) is roughly equal to the width of the door. The door is designed to fit within the average rib spacing. So you really can't go in through the wall any better than you could the door.
Excellent point!! So we'd have to cut out ribs...
I'm looking for the paper I wrote the dimensions of the equipment on... Also, I'm going to post some photos, and video shortly.
Old 01-25-2010, 02:44 PM   #17
_
ok, so the 'stream will eventually be a commercial kitchen/food thing?
or will those appliances just be part of the air-hut once it is livable?
lots of issues.
commercial kitchen redos are very involved.
power, water, 3 sinks, the weight, the ventilation, the windows, the CODEs and so on...
all doable but not anything like the typical rv rehab, EVEN as a shell off restoration.
___________
now about those applicances, here's a true story.
a friend wanted to start a coffee roasting business years ago,
so he ordered this expensive large heavy roasting machine from the FINEST italian maker of these things...
months passed and thousands of dollars later the machine arrived.
the problem was it was MASSIVE and would not fit into ANY door on his house.
and there was almost NO way to open up the house enough to get this thing into his basement...
so he hired a welder/boilermaker who proceeded to CUT this expensive hand built custom roasting machine into 2 pieces...
btw there were only 2 or 3 of these machines anywhere outside of italy at the time.
once the 2 pieces were in the basement the welder/boilermaker put it back together.
and a premium speciality roaster was born.
roasting began and now, years later this machine was the beginning of the 2nd largest coffee roasting company in the state...
(folgers is the largest)
of course they now have a large factory building with many roasters but the original machine is STILL in the family house...
____________
so maybe u should consider wacking the stove in 2, IF u are truely committed...
cheers
2air'
Old 01-25-2010, 02:49 PM   #18
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Deconstruct the appliances. Will the door come off? Compressor and box off, get it in and then put back together. Split the case on the refrig. REassemble with a seam in the back? Appliances can usually be taken apart and reassembled more easily than the Airstream.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 01-25-2010, 03:48 PM   #19
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Are we talking a pro stove? If it's not purchased yet, how about separate wall oven & cooktop? They are both available in professional styles & already propane usable. I used to work for a wholesale kitchen distributor. Many of the "professional" appliances we sold were not UL approved for commercial use. (Wolf, Thermador, Bocuse)
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 01-25-2010, 07:32 PM   #20
Rough crowd... Although the convertible idea has me intrigued. I wonder if ZipDee could make a giant retractible soft top. Hrmmm, maybe better to contact Jeep for that job?
Old 01-25-2010, 08:27 PM   #21
Looks like someone has already come up with a solution. Pop down the top and throw the appliance over the side...
JeepStream? AirJeep? Maybe this one is better left OFF the drawing board. How 'bout them axles though?
Sorry. Bored and having way too much fun with Photoshop.
Old 01-25-2010, 11:52 PM   #22
1976 31' Sovereign
portland , Oregon
Well, between us chickens, it's for a TV show. We want it to be up to code as long as we're doing all the hard work, but it's not imperative.
____________
What a FANTASTIC story!! Thanks, it made me laugh since it's SO familiar...
Old 01-25-2010, 11:56 PM   #23
1976 31' Sovereign
portland , Oregon
I think this idea is worth pursuing, I'll ask our equipment guy to let me know what he thinks. I suspect he'll think we need even more expensive equipment :-).
Old 01-26-2010, 12:01 AM   #24
1976 31' Sovereign
portland , Oregon
Ricky
MAHALO!!!!
Commercial. Good question though, I totally get what you're saying about "pro" kitchen equipment that's really for domestic use...
No oven, so you're right, I bet we could get the cook top off, the bottom is really just like a big shelf for pans... We had the gas professionally changed out for propane use.
It's a Wolf stove, I'll see if I can get the model number, that might give me additional clues :-). The vendor that switched it over to propane might be able to advise me as well.
I'm so inspired!!
Old 01-26-2010, 12:05 AM   #25
1976 31' Sovereign
portland , Oregon
Oh, MAN that's AWSOME!!! You had me going, but it's pretty freakin brilliant.
Old 01-26-2010, 07:46 AM   #26
1977 Argosy 24
Milltown , Wisconsin
Make a removable roof panel. Make the hole where the air conditioner would go, then the seams would not be visible from the ground. Cut out the roof and any ribs to get the hole big enough to drop the appliances in from above, and then rivet a strip of aluminum about 4 inches wide all around the piece you removed. Then when you put it back together you have a flange to calk & screw the removed section back into the trailer. Good luck, Brian.
ventport is offline   Reply With Quote
Old 01-26-2010, 03:12 PM   #27
1976 31' Sovereign
portland , Oregon
I really like this idea.
Maybe replace the panel with a skylight? Not sure what effect that would have on stability, probably little to none? Easier to get the equipment out later if required...
door size
large vent mitsy Roof 5 11-22-2009 02:55 AM
Trailer too Large? TV too small? pixiehat Tow Vehicles 45 03-13-2009 09:36 AM
Looking for a large gutted A/S kdenault Our Community 5 05-11-2006 10:44 AM
proper bulb for large door light? IPM General Motorhome Topics 3 03-19-2006 06:27 AM
A Large Family Janets Husband Our Community 15 02-25-2004 08:53 AM
