I'll add some important info though, if you tend to sit in one place for several days at a time. Even when you have full hookups, you should leave the dump valve closed and dump the tank periodically (before 100% full, as you've now learned!) so that the solid stuff in the tank has a chance to dissolve into the liquid stuff and/or be carried out on a more significant flow of wastewater when you're dumping. On a trailer with separate gray and black tanks you can leave just the black tank closed and accomplish the same thing, but with a combined gray/black tank you just have to watch the level or develop a habit of dumping every couple of days.
— David
