04-26-2018, 08:41 PM
2017 30' Flying Cloud
Cedar Park
Help! Tire blow out and ripped out gray water valve pull rod
So - I am in the middle of nowhere texas. I blew out a tire and somehow destroyed the gray water valve pull rod.
I have no clue how this happened. There is a fair bit of general damage to the black panels underneath and the valve rod "lock/holder" has been ripped out.
I leaked gray water all over - seems that the valve opened and filled up the discharge pipe. Water was coming out the opening where the pull rod entered and seems to be generally leaking. However, my tank was fairly full and there was plenty to empty upon arrival at the Koa.
I just started my vacation - don't want to turn back to Austin.
Any idea if I can do anything to fix this while on the road?
04-26-2018, 08:53 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Yes the repair can be done on the road. Pictures would help with details. Dump valves are replaceable and the metal work as long as it’s not rubbing anything or causing any other problems other than cosmetic can be done later.
04-26-2018, 09:23 PM
Cedar Park
Water is Dripping from the back corner.
04-26-2018, 09:57 PM
1995 25' Excella
xxxxx
, xxxxxx
I assume your pull rod is similar to mine. There is an extended rod riveted to the rod that comes out of the valve. The problem is that the riveted joint is hidden by the belly pan. You either have to drop the pan or cut a hole in it to drill out the rivet and put a new extension on.
If you have water dripping out of the pan, I suspect the dump valve is also damaged.
04-27-2018, 06:57 AM
Cedar Park
Thank you - that makes sense.
04-27-2018, 09:08 AM
2012 23' FB International
Woodstock
, Ontario
Pull Rods are fairly common spare parts at RV dealers; they are not specific to Airstream. You can probably jury rig something till you get home. If the bracket holding the rod was torn off you may have to go to an AS dealer but check with the closest RV supplier.
JCW
04-27-2018, 09:19 AM
1969 25' Tradewind
Shasta Lake
Valtura makes a twist on drain gate valve. You just twist on the outlet pipe on your rig and your good to go.
Should be able to get at a good rv parts dept. or Amazon
This will change your dump procedure to Gray water first then black.
04-27-2018, 09:55 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Had this happen in the middle of the Imperial Valley desert, though our blow-out also fractured the neck above the gray valve. If you are staying at a KOA, you likely have a mobile RV service nearby. When we got to our destination, we sourced a service, and they had us fixed in a day. Maybe more expensive, and may diddle with your schedule a bit, but it was less hassle for me at the time.
04-27-2018, 10:02 AM
2014 25' Flying Cloud
Temple
Are you close to Dublin TX - BAYER Airstream is a good place for repairs. My Airstream is there right now getting some work done for tire damage.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
04-27-2018, 11:12 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Any info on tire too?
04-27-2018, 04:31 PM
2016 30' International
Quartz Hill
A piece of 18 wheeler tire tread broke my gray valve completely off. I stopped in Vegas for the night. The RV park desk recommended a good mobile RV repair service. They had me back on the road the next morning in a couple of hours.
04-27-2018, 07:46 PM
Cedar Park
Good to know - tire was ripped to shreds. Discount tire set me up with 4 new ones - they were ready to be replaced anyways. Apparently I had uneven wear - may have an axle issue...
05-06-2018, 06:59 PM
2017 28' International
Jim Falls
, Wisconsin
I do not understand why AS leaves the sewage area exposed behind the tires. I’ve decided I need to get some protection like mud flaps or something in that area.
06-24-2018, 09:46 AM
Cedar Park
Bayer RV had me fixed up for about $4k and 5 weeks. Nothing to complain about now but I am sure I will find something to complain about [emoji16].
It was recommended I get 16" wheels next time I need new tires, so I am going to plan for that in 2019/2020.
