Old 06-27-2016, 09:42 PM   #1
Help, Shore Power CB Keeps Tripping
Why does the shore power 30 amp circuit breaker keep tripping? I'm running my refrigerator, water heater, and air conditioner, along with one TV at the same time. Is that enough to trip the 30 amp circuit breaker?
jonnie3 is offline   Reply With Quote
Old 06-27-2016, 10:04 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have had the same thing happen 4 or 5 times since we've had the 2015 Flying Cloud. I thing that the electric water heater function is the culprit. We had over 1,500 nights in our 2005 Safari, and it never happened. In the 2005 the water heater was gas only.
Brian
SuEllyn & Brian McCabe
Old 06-27-2016, 10:51 PM   #3
RonaldC303's Avatar
Washington , Utah
These are current draws as measured by my surge protector:
AC 13-14 amps depending on size
Water heater 11 amps
Refrigerator 2 amps
Converter -- dependent upon state of battery charge
Hope this helps you.
Ron
RonaldC303 is offline   Reply With Quote
Old 06-28-2016, 04:48 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
My guess is water heater the load culprit, our 2012 did this. Our 50 AMP 2015 has not, with both AC running and everything else on including microwave and a hair dryer.
Try not leaving WH on all the time and see if it helps would be my suggestion.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-28-2016, 08:27 AM   #5
Sioux Falls , South Dakota
Our mpg was a 30A rig, and our Foretravel is 50A. When we have to use 30A we have to carefully monitor power use. 30A is ~3600 watts. I'd suggest that you run the hot water heater on propane when you are running the a/c. Turn the a/c off when you run the microwave or coffee maker.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 06-28-2016, 08:34 AM   #6
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Simple answer is yes.
When in our MH I try to "manage" my power. We always leave the water heater off unless getting ready to do dishes or shower. We turn off other devices when not needed as well.
Best to do a survey and try to get a list of the appliances and their power draw. After you have that list this will all make better sense.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 06-28-2016, 08:59 AM   #7
Long Island , New York
Did you try switching the water heater to propane?
OTRA15 is online now   Reply With Quote
Old 06-28-2016, 11:23 AM   #8
jackson center , Ohio
How many volts coming into Trailer?
Schu is offline   Reply With Quote
Old 06-28-2016, 01:26 PM   #9
1973 31' Sovereign
Middletown , California
Some breakers are weak and others get that way over time. If making a bad connection they can run hot and trip easy. Also if in a hot environment they can trip at a lower current. Feel the breaker to see if it runs hot. Try turning the water heater off when not needed. Would be nice to know the voltage and amps you are drawing when problem occurs.
ijustlee is offline   Reply With Quote
Old 06-28-2016, 09:05 PM   #10
1988 32' Excella
Robbinsville , New Jersey
An important thing that many people don't realize is that you should not use more then 80% of a circuit breakers rated capacity for en extended amount of time. This means you should keep the load on a 30amp breaker below 24amps.
At least that is what I have been told by a couple of electricians.
Help! GFCI keeps tripping. Sjcjr Electrical - Systems, Generators, Batteries & Solar 13 06-01-2016 10:45 PM
Shore power tripping strickland Electrical - Systems, Generators, Batteries & Solar 5 10-13-2015 11:07 AM
Tripping ground fault on shore power.A few days ago it was pouring rain so I went to Coaster Batteries, Univolts, Converters & Inverters 4 03-11-2014 03:55 AM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
GFI Tripping - Attaching Shore Power Procedure? big_john Batteries, Univolts, Converters & Inverters 0 11-24-2009 07:15 PM
