Old 04-05-2015, 09:38 PM   #1
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Help! Shell coming off
What type of screws do you recommend to attach 2x4's to ribs?
2Rhinos is offline   Reply With Quote
Old 04-05-2015, 11:02 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Which ribs? The shell ribs?as in the ones that go from floor-wall-roof then back to the floor?
What are you planning to 'hang' on the 2x4? Ideally you would want the floor to support the 'load'...
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-06-2015, 04:37 AM   #3
Baltimore , Maryland
Why damage the ribs with screws?
Old 04-06-2015, 07:30 AM   #4
1985 31' Sovereign
Lovettsville , Virginia
I believe the OP is not intending to hang anything on the 2x4s, but rather use them for bracing when removing the shell from the frame. I could be wrong.
85 Sovereign is offline   Reply With Quote
Old 04-06-2015, 08:29 AM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
How are you executing your lift, ie. jacking up against the bracing you are talking about installing, or hoisting from above? If you are hoisting, then bracing is not needed.
Old 04-06-2015, 04:37 PM   #6
1968 24' Tradewind
Carlsbad , California
I lifted mine last week with just a 2x6 and a pair of chain hoists--no issues. I'm indoors though and have no concerns of wind or other external factors.
If I was out doors I might consider bracing and anchoring it to protect from wind.
shilgemann is offline   Reply With Quote
Old 04-06-2015, 08:42 PM   #7
SpitFireRX's Avatar
1979 31' Excella 500
Florida , Florida
Carriage bolts 😄
SpitFireRX is offline   Reply With Quote
Old 04-07-2015, 09:39 PM   #8
1979 23' Safari
Wayland , New York
1/4 inch is more than enough
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
