Old 08-07-2014, 08:34 AM   #1
VNO
1975 Argosy 24
Germantown , Tennessee
Help Please! I'm in a pickle.
Morning ya'll. Parked here in Huntsville Alabama for the kids to go to robotics camp, and the door handle on my '74 Argosy broke this morning and would not open from the inside (picture two kids and a mom with hands and noses planted on the glass wrap around window pleading for help hahaha!). A neighbor opened the door for us to spring the kids for camp, but I need to fix this.
It appears to be a connecting rod inside the door, and I don't know where to even start aside from taking a box cutter and cutting around handle, which I can do (but don't want to).
If I get inside, will I be able to get parts at Lowes to repair it or is this a "only on planet Airstream" part?
Thanks ya'll.
Eaglemate is offline   Reply With Quote
Old 08-07-2014, 08:44 AM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
I think it's going to be a Airstream only fix.. Out of Doors Mart has nice pics and most of the parts you need.
1970 to77 Airstream Lock : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Damon
#4827
damonbeals is offline   Reply With Quote
Old 08-07-2014, 08:46 AM   #3
VNO
1975 Argosy 24
Doggonit. OK. Thanks for the referral.
Old 08-07-2014, 08:48 AM   #4
VNO
1975 Argosy 24
Well, new at this, but to get to the mechanism should I cut into the unit with a box cutter or remove the rivet and screws on the entire door?
Old 08-07-2014, 08:52 AM   #5
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Try to get at it by removing rivets only....do no damage that you will regret later. You can always re-assemble the door/panel.
arktos55343 is offline   Reply With Quote
Old 08-07-2014, 08:52 AM   #6
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
You can take the whole assembly out. Remove the inside handle first. Then there are a couple screws on the inside of the door and one on the edge of the door holding the whole assembly. It is then removed from the outside. Some wiggling is required.
You then can look at the assembly to see what mat have loosened or broke.
If my memory serves me right, I can only think of 2 possabilities. Your inside handle is screwed onto a shaft. Either the screw came loose or the shaft has broken.
You will not find the shaft at any hardware store. If it is available, you will find it at 'vintage trailer supply' or 'inland rv'.
Hope this helps.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 08-07-2014, 10:08 AM   #7
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Here is an exploded view posted on Out the door marts sit. Hope it helps. Call them.
Name:	KT ExplodedView1.jpg
ID:	218524   Click image for larger version
Name:	KT Top view.jpg
Name:	KT Rear view.jpg
montanablue is offline   Reply With Quote
Old 08-07-2014, 10:14 AM   #8
VNO
1975 Argosy 24
OK, great idea. Screws are out and half the unit, but that sucker is stuck in there. I'll keep working it. Thanks!
Old 08-07-2014, 10:15 AM   #9
VNO
1975 Argosy 24
Excellent diagram and thanks for posting it. Helps me visualize what I am looking for and I appreciate it more than you know.
Old 08-07-2014, 10:21 AM   #10
VNO
1975 Argosy 24
OK, this unit is stuck like a strawberry up the nose of a kindergartner. Shall I pull hard?
The latch is depressed and recessed as far as I can get it and it's almost out, but something seems to be holding it in place.
Old 08-07-2014, 10:28 AM   #11
1997 25' Safari
1973 25' Tradewind
Make sure you remove the screws at the edge of door where the latch comes out
Old 08-07-2014, 11:07 AM   #12
VNO
1975 Argosy 24
Montanablue, I did. There was just one, correct?
Old 08-07-2014, 11:18 AM   #13
1997 25' Safari
1973 25' Tradewind
Someone might have use some rv putty around edge of outside lock. Take a putty knife and go around edge to try release it
Old 08-07-2014, 11:20 AM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Help Please! I'm In A Pickle.
Chances are good that you only have a broken roll pin in the on the inside handle shaft. Notice how the cam on the shaft contacts a roll pin to pull back the bolt. Available at most auto parts or hardware stores. A punch and hammer will be required to remove the broken pin. The punch must be no larger than the roll pin.
You may have to remove some rivets from the inside skin and pull the skin (gently) away from the door in order for the inside handle shaft to have enough clearance for removal of the assembly from the outside.
Slamming the door is one of the reasons these pins shear off.
Tin Pickle :: 1971 Airstream Land Yacht Trade Wind webspinner Airstream Registry Discussions 1 03-05-2014 05:17 PM
Tin Pickle :: 1971 Airstream Tradewind barts Airstream Registry Discussions 0 08-19-2011 08:31 AM
Tin Pickle's first trip barts On The Road... 5 06-02-2010 08:47 AM
1975 Argosy Motorhome *The Pickle* BigDill Member Introductions 2 08-12-2006 08:06 PM
Hold the pickle…… azflycaster Airstream Trailer Forums 9 06-13-2005 06:37 PM
