Old 03-12-2012, 09:40 AM   #1
AirEPotter's Avatar
2011 27 FB International
Lubbock , Texas
Help! On the road and fridge isn't cooling
Between Texas and New Mexico and fridge isn't cooling. Two year old Dometic fridge. I have good power (fuse is good and Led display is working). Last night plugged into shore power on "auto" fridge setting and this morning fridge was 57. Switched it to LP and still isnt cooling. Full bottle of gas so that's not issue. What's weird is that even plugged into shore power and setting on "auto", the display still has LP light on. It's never done this before. Not sure how that factors in. Any help would be appreciated as theres no RV repair anywhere around. I apologize for cryptic post but I'm doing this from a cell phone. Thanks.
AirEPotter is offline   Reply With Quote
Old 03-12-2012, 09:43 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Try disconnecting the power, (shut fridge off) for a few minutes and then try again to see if panel display is correct.
LPG should be the most efficient energy for the fridge, but will take some time to cool this style of fridge.
Dave
Old 03-12-2012, 09:48 AM   #3
1974 Argosy 20
Kooskia , Idaho
Also, if you still have campground power, be sure that you are getting power to the refrigerator outlet. When the light stays on LP it could be not switching due to lack of 120 volt power, but that does not explain the lack of cooling on LP.
Old 03-12-2012, 09:54 AM   #4
1974 Argosy 20
Kooskia , Idaho
Also, remember that it takes a couple of hours to notice that the cooling is working, once you make a switch over. RV refrigerators are slow to cool.
If you can, check to see that the "chimney" (about a 4" diameter tube on the right side from the back) is warm or hot. If not, something is not working. Can you see a flame when on propane?
Just things to look for and report back.
Old 03-12-2012, 09:59 AM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Bummer. What model number is the fridge?
Is there a rear access panel? If so, remove this and see if the chimney is hot. If it is working the chimney will be hot either from the propane burning or the electrical element heating.
Dan
Old 03-12-2012, 11:05 AM   #6
AirEPotter's Avatar
Lubbock , Texas
Thanks for all the quick responses. This site never ceases to amaze me with all the friendly and helpful people. Good news is it seems to have healed itself!! Its now down to 45. My guess is the power off back on did the trick. Thanks again.
Old 03-12-2012, 05:58 PM   #7
AirEPotter's Avatar
Lubbock , Texas
Ok, the plot thickens. Just pulled into the RV Park in Taos and for some reason even when I'm hooked to shore power my trailer is not powered. I'm plugged to 30amp but no power to any outlets inside. I'm certain there is power to the outside because my 30amp plug has a blue light and it's on. What would cause there to be no power to outlets? In sure its something simple. Help please?
Old 03-12-2012, 06:02 PM   #8
1974 Argosy 20
Kooskia , Idaho
Have you checked the circuit breakers inside the trailer to be sure they are all on?
Old 03-12-2012, 06:22 PM   #9
AirEPotter's Avatar
Lubbock , Texas
it was a breaker. Thanks.
Belly skin and Banana Wrap Alloy perryg114 Belly Pans & Banana Wraps 16 03-03-2014 05:12 AM
It's Monday and I love my Airstream because..... THEPILL Off Topic Forum 4 03-12-2012 11:10 PM
Help! On the road and fridge isn't cooling AirEPotter General Repair Forum 8 03-12-2012 06:22 PM
restore emblem-help goshawks00 General Repair Forum 6 03-12-2012 04:23 PM
PINK, VINTAGE and READY! 1967 Concession Airstream Trailer eBay Watch Airstreams on eBay 0 03-12-2012 02:40 PM
