Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-04-2014, 09:24 AM   #1
Rolling Meadows , Illinois
HELP! Newbie with a leak
Hi Everyone
I'm one week away from fulltiming in my new-to-me 1962 Avalair.
Just when I thought all was well and as I started placing my belongings before having my estate sale (after spending a ton of money paying for a new hot water heater, new FW tank, new piping throughout and other essentials) Mother Nature did me a great favor by sending a gentle steady rain.
Thus was revealed the leak around the brand new hot water heater.
My first guess is that the exterior was not appropriately sealed. However, I'm not very sure of this because this clearly is the site of a previous leak given the water heater was completely rusted and the floor in that area completely rotten.
The tech did some nice work and replaced everything and re-built the outer housing with a minimum of new panel.
As a first step, I thought I should try to do some sealing in the only place that seems to need sealing--the miniscule crack between the uppermost panel and the outer skin on the outside. But when I open up the panel I find it very well sealed so I don't really see how water could be getting inside.
The inside shows only a leak near the hw heater. The area above doesn't show leaking but it might be doing so between the outer skin and inner wall. Can't tell.
What do I try to seal that with? If I were in my house I'd use clear caulk. But this is a trailer I hope to polish someday.
What should I use?
Second question which is just as urgent but has little to do with leaking (except if you like puns). Does my sewer connection have a currently made adapter? See pic. I've been told I can't attach a sewer hose without a special adapter. I searched forums for a pic of an old style pipe and I saw a recent thread entitled "macerator" but it didn't have pics so I'm unsure if I'm in that very enviable category of having an old style connection.
Thanks so much.
Sophia
SophiaRose is offline   Reply With Quote
Old 06-06-2014, 11:12 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'll answer on the waste adapter - it looks like your waste system uses Thetford connectors (the current ones are Valterra). The good news is that Valterra makes a Thetford-to-Valterra adapter - see Amazon.com: Valterra T05-2285VP Thetford to Valterra Universal Adapter: Automotive which only costs about $7.00. Buy two, so that if the plastic breaks you have a spare.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Newbie with a roof leak JackP Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 05-06-2009 10:20 AM
Newbie with a roof leak. Please Help! JackP Member Introductions 0 05-04-2009 07:52 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
