Old 08-30-2016, 04:03 PM   #1
Loma , Colorado
Help Hooking up Converter
I have a older Converter. I need help with the wireing from the Battery to my 110V The battery side. Red wire is Battery poss. The Black is Load Pos. And the Yellow wire is Load Com. And the 110 Side is ,Black wire is 120v, tan is Com. and blue wire is ground. I know where the Positive goes. I need to know where the rest goes. Can someone help. It is a Saf-T-Trail Converter I tried to upload a pic but was unable to.
swenson_ed is offline   Reply With Quote
Old 08-31-2016, 09:24 AM   #2
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
The converter is the go between the dc battery and the 110 v ac system. I would give BestCoverters a call and see if they can help you or may a schematic. 110 v ac and 12 v do don't mix without a transformer / converter.
Typically you have three wires (black, white, green) from converter that go to 110 v ac circuit and two go to the 12 v circuit. The battery itself connects into the 12 v do circuit.
Good luck.
Kemblkr is offline   Reply With Quote
Help! On the road and need assistance with hooking up water Jessie Plumbing - Systems & Fixtures 19 04-20-2015 08:21 AM
Nubie question on hooking up converter... Fireside79 Batteries, Univolts, Converters & Inverters 2 06-24-2014 12:10 PM
Hooking up Tekonsha to a Tundra Help Needed! Libo Brakes & Brake Controllers 2 01-27-2009 12:00 AM
HELP! Hooking up tank/pump/sink Jephellis Fresh Water Systems 0 08-13-2008 07:33 PM
Need help hooking up gas stove Jephellis LP Gas, Piping, Tanks & Regulators 3 07-08-2008 07:54 AM
