Old 11-27-2015, 09:39 AM   #1
1967 26' Overlander
Anywhere , USA
Help! A/C-Heater Caught on Fire!
Last night, our ceiling mounted A/C-Heater caught on fire. Luckily, I woke up immediately and put it out so no damage.
What do I do next? Who typically repairs or replaces these units? It's a 1967 Overlander. A/C is an older unit and doesn't work that great anyway.
Diogenes is offline   Reply With Quote
Old 11-27-2015, 10:55 AM   #2
1986 31' Sovereign
Miami , Florida
Pretty much any reputable RV shop can work on it but I would think that replacement would actually be more cost effective if it is, as you say, old and not working well.
The classic replacement is the Dometic Penguin. Installing one in an Airstream is a little different than most SOB's as there is provision for a condensate drain that runs through a hose and down inside the wall to a low point. A good RV tech, with a modicum of Airstream experience can replace it, I believe there is a unique tray that it used to provide for the interior drain.
There are other units that deal,with the condensate without provision for a drain but I am unfamiliar with them.
All generally will fit in the standard roof opening.
If I was replacing mine, I'd go for an upgrade to a 15k BTU unit vice the 13.5k BTU that I have now.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 11-27-2015, 11:14 AM   #3
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
Contact Uwe at Area 63 in Lytle Creek area63productions.com he specializes in Vintage repairs/restoration as well as work on new models.
LilNomad
LiLNomad is offline   Reply With Quote
Old 11-27-2015, 01:09 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Don't use the heat element. Go buy a 25 dollar electric heater at Home Depot, Lowes, Big Lots or Wal-Mart. Then when you feel up to it replace the entire AC unit.
Old 11-27-2015, 04:02 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I agree with Melody - don't go with an Air Conditioner with heat strips - the $25 heater does the same thing and is quieter - and isn't on the ceiling.
BUT you might want to consider a Heat PUMP which is basically a reversable air conditioner. If you've ever stood outside when a window air conditioner is running you know it gives off heat, on a cold day a heat pump blows the heat inside. The first one I had on a 2006 Safari only heated down to about 42 F. The one on my 2012 works down to about 37 F, so there's been significant improvement. Below 37 F. I either set the system on AUTO to switch to the furnace, or turn off the compressor (fan on can be nice) and use the little $25 space heaters.
Don't waste your time considering repairing the old unit. The parts are probably no longer made or stocked and labor - well a new one would be cheaper AND more efficient.
Paula
Old 11-28-2015, 03:13 PM   #6
1967 26' Overlander
Spartanburg , South Carolina
We also have a '67 Overlander with the Original Armstrong A/C up top. Still works great (knock wood) but doesn't have heat strips. We use a small space heater which does the trick most of the time, but nothing beats the gas furnace for a quick warm-up. I have heard several comments from the Vintage folks at WBCCI that the Armstrongs are nearly "bullet proof" and parts are available, probably from Silver Trailer Supply in Utah or Vintage TS in Vermont. We plan to keep ours as long as we can.
Jacob D is offline   Reply With Quote
Old 11-28-2015, 03:53 PM   #7
1967 26' Overlander
Anywhere , USA
Looks like we have a replacement A/C then. It's a Coleman.
Warmly, Beth
"wherever we go, we're always home"
Old 11-29-2015, 09:05 AM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Warmly, Beth
Ha!
2012 Dodge Durango Hemi/AWD
Help my solar controller caught on fire bmklawt Generators & Solar Power 28 03-24-2016 11:02 AM
Airstream Caught Fire traveling through our town. Cantrell Airstream "In the News" 12 09-24-2012 04:53 PM
Water heater caught on fire Bill M. Water Heaters, Filters & Pumps 12 06-30-2011 06:37 AM
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 10:29 PM
