Old 05-04-2012, 01:50 PM   #1
1999 25' Safari
Ellijay , Georgia
Send a message via Skype™ to jdanielii
Help!!!
I have my Dometic refrig pulled out to replace the cooling unit. It turns out to be a pretty good job, but thats not why I am asking for help. I read somewhere that putting a small fan behind the refrig to help exaust hot air would vastly improve the efficientcy of the frig. Has anyone done this and did it work? What kind of fan? How is it hooked up, ie what makes it come on and go off? Thanks for any help.
jdanielii is offline   Reply With Quote
Old 05-04-2012, 01:56 PM   #2
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
My 2008 20' Safari has an auxilary fan. The fan switch is located on the side panel next to the refrig at the door of the TT.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 05-04-2012, 02:15 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Somewhere in the past I read the item your referring to. The person installed a computer cooling fan in the rear by the air inlet screen in the floor. I think it was in a 66 Caravel.
Old 05-04-2012, 02:29 PM   #4
a , wanderer
Here is one that several people use and that I'll be installing shortly.
Snyders RV Refrigeration - Home
Kyle is offline   Reply With Quote
Old 05-04-2012, 02:41 PM   #5
Grumpycamper's Avatar
2005 16' International CCD
Wimberley , Texas
I have a small metal fan from wal mart in mine, I plugged in in with a 3 way adapter. I really don't think it helps much. Good luck!
Avatar 1954 13' Airlight
Grumpycamper is offline   Reply With Quote
Old 05-04-2012, 04:00 PM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We bought this: Solar Fridgecool Fan - $48.22
I have yet to install it though.
Old 05-04-2012, 05:42 PM   #7
1986 31' Sovereign
Miami , Florida
I am a thrifty sort of guy (my wife says "cheap". Went down to the local recycling center and found an old desktop computer. Removed the power supply box (usually a cube about 8" x 8") gutted it except for the fan (which, coincidentally, is almost universally a 12volt unit) Mounted it on the wood deck immediately behind the fridge pointed upward and ran the leads to the 12v terminal at the fridge terminal box (I do have an inline switch) and, Voila!. Cheap. Has worked now for some three years.
mike
Old 05-04-2012, 06:01 PM   #8
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Almost like Mike: Radio Shack 12v computer fan bolted to wood deck behind fridge pointed up with some spacers to lift it about 3" for circulation, 9" of insulated wire with an in-line switch wired to terminal box. It does make a noticeable difference. You just want to remember to turn it off when you aren't using the TT.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 05-04-2012, 09:58 PM   #9
dznf0g's Avatar
Oswego , Illinois
I did the same thing, except I also got a thermal furnace switch (normally open, 140* close temp) and installed it inside the insulation within the chimney. Whenever the fridge is on and heating, the switch closes and the fan turns on. When I shut off the fridge....about 30 minutes later, fan shuts off. I also have a manual switch inline, so I can shut off in cool weather or when boondocking.
-Rich-
