Old 09-25-2016, 09:56 AM   #1
groovzilla's Avatar
1963 19' Globetrotter
Seattle , Washington
Help - 7 pin trailer connector "to" 4 pin vehicle
All,
My 1965 Airstream Tradewind has the original 7 pin round connector (1st 2 photos)- is there a conversion pigtail so i can connect it to my land rover's 4 pin connector (3rd photo)?
photos below
thx in advance!!
Name:	7 pin connector.jpg
ID:	272318   Click image for larger version
Name:	7 pin connector 2.jpg
Name:	4 pin connector.jpg
groovzilla is offline   Reply With Quote
Old 09-25-2016, 10:03 AM   #2
Gainesville , Florida
If there is I don't think you would have trailer brakes.
Old 09-25-2016, 10:14 AM   #3
1976 31' Sovereign
Oswego , Illinois
Yes can pur. or make one, simple to do. There will not be any trailer brakes w/4pin connector, only tail lites stop and turn, 4th ground. No trailer brakes bad idea, and dangerous. I do this adapt. for single axle small boat trailer and small utility trailer, neither have brakes, so no danger. Bill
Old 09-25-2016, 10:55 AM   #4
groovzilla's Avatar
where can i purchase a 7 pin round female "to" 4 pin flat adapter??
**i do not need brakes - just towing short distance**
i have searched everywhere and only find 7 blade female adapters not round?????
Old 09-25-2016, 11:07 AM   #5
richw46's Avatar
Lexington , Kentucky
eTrailer has a 'fit' guide. Looks like you'll have to make one. They have the parts but you can probably go to Lowes, Home Depot or an auto parts store and get the pieces you'll need. I might suggest you just get the male flat plug and splice that to the round plug's wires for a temp fit
http://www.etrailer.com/wiring-adapt...lat&tw=7-Round
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-25-2016, 11:33 AM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
There is not adapter to go from 4 to 7, there is a reason for that, Hello, the 4 pin is for a single axle boat trailer w/o brakes or charging wire... If going a short ways , pull it with your bicycle ...
Old 09-25-2016, 12:28 PM   #7
1976 31' Sovereign
Oswego , Illinois
Cool
They make flat 7 pin adapter to 4 pin as I have pur many [to lazy to make]. 4 pin is used for many trailers besides boat trailer that doesn't have brakes. Bill
Old 09-25-2016, 12:35 PM   #8
1976 31' Sovereign
Oswego , Illinois
Try uhaul for adapters as they have lots of weird set ups. Bill
Old 09-25-2016, 12:37 PM   #9
richw46's Avatar
All the adapters I was able to find are for a 4 pin male trailer plug to a round TV connection. They have them for flat or round pins. I could not find any for a round or flat 7 pin trailer to a 4 pin TV connection.
The easiest way would be to just splice a 4 pin male plug onto the wires of the round 7 pin. There would not be any trailer brakes, agreed, not the best situation. If the TV has only the 4 pin flat plug now I would think the best thing to do is to convert to a 7 pin flat connection, going to need one anyway. Then you just need a round to flat pin adapter for the AS.
http://www.etrailer.com/Wiring/Hopkins/47595.html
-Rich
Rich & Yvonne
2004 4Runner SE
Old 09-25-2016, 12:47 PM   #10
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
Install a 7 contact flat blade round connector on the trailer.(Link below) You can then buy that adapter to 4 flat. (link) The flat blade contact round connector is more universal these days and would probably be what you would want to use if you ever did need brakes or bought a truck. Most trucks come standard with the flat blade plug and many with the 4 flat also. If you convert the trailer, you'll be done. These items may be available at some camping RV dealers too. Main plug almost for sure. Adapter, maybe not. If your Range Rover wiring is properly grounded, the ground in the flat plug will be adequate for lights. The extra wires on the adapter are for 12v or other uses and the extra, heavier ground is for those purposes. You should be able to plug and play after you install plug on the trailer.
https://www.amazon.com/Reese-Towpowe...ler+plug+7+way
https://www.amazon.com/57184-4-Way-7...railer+adapter
fwjumper is offline   Reply With Quote
Old 09-25-2016, 12:56 PM   #11
1973 31' Sovereign
Middletown , California
Just buy the 4 pin plug at any auto parts store or WalMart and strip about an inch of insulation off the wires. Fold the bare wire up into a wad and stuff the right wire into the right hole of the 7 pin. I do this a lot. I have even stuck the brown wire into the brake connection and a 25 amp fuse into the tail light spot so in case of really needing to stop I can turn on the parking lights. Yes, I want to be a Redneck when I grow up. Make sure you have good insurance also.
ijustlee is offline   Reply With Quote
Old 09-25-2016, 01:03 PM   #12
1991 25' Excella
Stanfield , Oregon
Check with farm supply stores or auto parts stores the adaptors are out there I've got one in the garage I haven't used in years.
SpletKay06 is offline   Reply With Quote
Old 09-25-2016, 01:03 PM   #13
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Available at any RV, auto, boat parts store or the ever present wallyworld. Very common device.
MICHAEL
Old 09-25-2016, 01:08 PM   #14
1977 31' Sovereign
2005 30' Safari
North Port , Florida
This is what I would do for a temporary inexpensive fix.
http://www.etrailer.com/Wiring/Tow-R...FcNkhgodAEkG4w
https://www.etrailer.com/Wiring/Hopkins/HM47115.html
cliffcharb is offline   Reply With Quote
'06 Expedition 4 pin to 6 pin connector ALANSD Towing, Tow Vehicles & Hitches 20 02-05-2015 10:50 AM
6-pin connector to AS 7-pin Ruben J Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
7 Pin Male Trailer Connector. firedog Electrical - Systems, Generators, Batteries & Solar 0 07-31-2007 02:02 PM
