09-25-2016, 08:15 PM
#21
1963 19' Globetrotter
Seattle
Originally Posted by TxDave
gee whiz your wrong - those are flat 7 blade connectors not pin connectors
1968 22' Safari - All Original
09-25-2016, 08:17 PM
#22
Seattle
Originally Posted by SpletKay06
thank you very much - earlier i found the correct male adapter to be wired/mounted on my land rover tow vehicle made by pollak - their webpage photo shows the 7 pin trailer "female" and on the right the connector for the tow vehicle:
http://www.etrailer.com/comparison.a...00&pc2=PK11720
09-25-2016, 08:38 PM
#23
Seattle
Tried the lights again after dark and found 2 clearance lights working - yeah
09-25-2016, 09:00 PM
#24
1978 31' Excella 500
Genoa
, Nevada
You're going to want to switch to the modern plug for both your tow vehicle and trailer. Sometime, somewhere you may need a buddy to pull your trailer over to that fishing hole for you, or you may need to pull your buddies fishing boat over there too. Easy if you both have the modern plug arrangement, instead of needing to figure out some wires in the mud in the middle of the nite
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
09-25-2016, 09:40 PM
#25
2000 27' Safari
Schaumburg
Good evening Airstreamers...
I certainly would not attempt to tow your trailer any distance without brakes. FYI, pop-up trailers weighing more than 2,000 lbs. are required by law to have electric brakes, and of course a seven pin trailer plug connection.
The correct action, which is also the safes,t is to have a seven pin plug installed on your tow vehicle, and have a new female plug installed on the AS. Pulling the trailer without brakes is opening yourself for some unforeseen liability should a mishap occur on the road.
"The safe Way is the Best Way" IMHO
Kindly;
Pressdr
09-26-2016, 07:40 AM
#26
1994 30' Excella
Milwaukee
, Wisconsin
I am not being rude but you said you do not need brakes since you are only towing a short distance. Can you explain what conditions you do not encounter in a short drive that you would encounter in a longer drive? Everything you find in a long drive can also be found in a short drive. We have been camp ground hosts for many years and I have seen numerous accidents within the state park with people towing without brakes, using too small of a tow vehicle or some other short cut to safety. You are not only putting yourself at risk but all the other people around you who are depending on you to be sensible and safe. Your Range Rover will not stop the trailer in an emergency. Most traffic accidents occur within 10 miles of your home. Maybe the fact that there is not an adapter for your use is telling you something; listen to what is being said and get your truck properly wired to operate the trailer brakes.
Chaplain Kent
Forest River Forester 2501TS
09-26-2016, 08:25 AM
#27
2013 30' Classic
Greenwood
, Mississippi
There should be no adapter that goes from stop/tail/turn 4-pin on a vehicle to 7 blade RV plug or horse trailer plug with stop/tail/turn, brakes, and charge.
The Rover needs to be equipped with a trailer brake controller and a 7 blade RV receptacle.
The horse trailer style plug should be removed from the trailer and a modern 7 blade plug installed.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-26-2016, 12:14 PM
#28
Seattle
thx all, perhaps my post was not clear.
i do intend on having my land rover properly wired for brakes and lights.
for now, i wanted a quick wiring of the lights so i could tow the trailer about 1 mile on flat level ground with no hills or traffic.
again thanks to everyone who posted.
09-26-2016, 05:50 PM
#29
1977 27' Overlander
Winnetka
U haul
09-27-2016, 05:18 AM
#30
Mantua
, Ohio
For one mile I would put it on the ball and drive slowly. No hookup for electric. Slowly.
