09-25-2016, 09:56 AM
1963 19' Globetrotter
Seattle
Help - 7 pin trailer connector "to" 4 pin vehicle
All,
My 1965 Airstream Tradewind has the original 7 pin round connector (1st 2 photos)- is there a conversion pigtail so i can connect it to my land rover's 4 pin connector (3rd photo)?
photos below
thx in advance!!
1968 22' Safari - All Original
09-25-2016, 10:03 AM
Mantua
, Ohio
If there is I don't think you would have trailer brakes.
09-25-2016, 10:14 AM
1976 31' Sovereign
Oswego
Yes can pur. or make one, simple to do. There will not be any trailer brakes w/4pin connector, only tail lites stop and turn, 4th ground. No trailer brakes bad idea, and dangerous. I do this adapt. for single axle small boat trailer and small utility trailer, neither have brakes, so no danger. Bill
09-25-2016, 10:55 AM
Seattle
where can i purchase a 7 pin round female "to" 4 pin flat adapter??
**i do not need brakes - just towing short distance**
i have searched everywhere and only find 7 blade female adapters not round?????
09-25-2016, 11:07 AM
I'm In
, Kentucky
eTrailer has a 'fit' guide. Looks like you'll have to make one. They have the parts but you can probably go to Lowes, Home Depot or an auto parts store and get the pieces you'll need. I might suggest you just get the male flat plug and splice that to the round plug's wires for a temp fit
http://www.etrailer.com/wiring-adapt...lat&tw=7-Round
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
09-25-2016, 11:33 AM
2013 31' Classic
billings
, Montana
There is not adapter to go from 4 to 7, there is a reason for that, Hello, the 4 pin is for a single axle boat trailer w/o brakes or charging wire... If going a short ways , pull it with your bicycle ...
09-25-2016, 12:28 PM
1976 31' Sovereign
Oswego
They make flat 7 pin adapter to 4 pin as I have pur many [to lazy to make]. 4 pin is used for many trailers besides boat trailer that doesn't have brakes. Bill
09-25-2016, 12:35 PM
1976 31' Sovereign
Oswego
Try uhaul for adapters as they have lots of weird set ups. Bill
09-25-2016, 12:37 PM
I'm In
, Kentucky
All the adapters I was able to find are for a 4 pin male trailer plug to a round TV connection. They have them for flat or round pins. I could not find any for a round or flat 7 pin trailer to a 4 pin TV connection.
The easiest way would be to just splice a 4 pin male plug onto the wires of the round 7 pin. There would not be any trailer brakes, agreed, not the best situation. If the TV has only the 4 pin flat plug now I would think the best thing to do is to convert to a 7 pin flat connection, going to need one anyway. Then you just need a round to flat pin adapter for the AS.
http://www.etrailer.com/Wiring/Hopkins/47595.html
-Rich
Rich & Yvonne
09-25-2016, 12:47 PM
1998 34' Limited
Lawrenceville
, Georgia
Install a 7 contact flat blade round connector on the trailer.(Link below) You can then buy that adapter to 4 flat. (link) The flat blade contact round connector is more universal these days and would probably be what you would want to use if you ever did need brakes or bought a truck. Most trucks come standard with the flat blade plug and many with the 4 flat also. If you convert the trailer, you'll be done. These items may be available at some camping RV dealers too. Main plug almost for sure. Adapter, maybe not. If your Range Rover wiring is properly grounded, the ground in the flat plug will be adequate for lights. The extra wires on the adapter are for 12v or other uses and the extra, heavier ground is for those purposes. You should be able to plug and play after you install plug on the trailer.
https://www.amazon.com/Reese-Towpowe...ler+plug+7+way
https://www.amazon.com/57184-4-Way-7...railer+adapter
09-25-2016, 12:56 PM
1973 31' Sovereign
Middletown
Just buy the 4 pin plug at any auto parts store or WalMart and strip about an inch of insulation off the wires. Fold the bare wire up into a wad and stuff the right wire into the right hole of the 7 pin. I do this a lot. I have even stuck the brown wire into the brake connection and a 25 amp fuse into the tail light spot so in case of really needing to stop I can turn on the parking lights. Yes, I want to be a Redneck when I grow up. Make sure you have good insurance also.
09-25-2016, 01:03 PM
1991 25' Excella
Stanfield
, Oregon
Check with farm supply stores or auto parts stores the adaptors are out there I've got one in the garage I haven't used in years.
Biloxi
, Mississippi
Available at any RV, auto, boat parts store or the ever present wallyworld. Very common device.
MICHAEL
09-25-2016, 01:08 PM
2021 16' Bambi
2021 22' Bambi
North Port
09-25-2016, 01:14 PM
Seattle
thx to all - does anyone have the 7 pin airstream wiring diagram showing various colored wires de-coded
09-25-2016, 01:16 PM
2014 25' Flying Cloud
Temple
I think I would go the other direction and add a seven wire connection to your TV. That way you do not mess with your original seven wire rev connector, You could still not connect a brake wire if you did not want too,
Remember those famous last words " I did not think I needed brakes"
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
09-25-2016, 07:42 PM
1976 Argosy 26
Fair Oaks
09-25-2016, 07:45 PM
1991 25' Excella
Stanfield
, Oregon
09-25-2016, 08:14 PM
Seattle
i did a little rigging experiment using a male 4 way adapter with long wire leads on my land rover's 4 way flat female plug - here is a photo of the tow wires i currently have working on the trailer - wires are marked and working on trailer. turn signals, tail lights work well and i'm amazing considering they haven't been used in years.
the clearance lights should be working(same wire as tail lights which work) but they all must be badly corroded so i'll take them apart tomorrow and clean them out. hopefully get them working.
so the 3 holes on the trailer connector which have no wire leads into their sockets are: brakes, charging line & reverse lights.
**does the charging line allow current into the trailer so the interior 12v lights will operate while hooked up to car??
