Old 04-04-2015, 01:17 PM   #1
1971 31' Sovereign
Hartsville , Tennessee
Help!!
I am replacing the floor on my 1971 Overlander and it seems that the rear radius left and right aren't symmetrical? Is this normal or do I need to make.them match? The fronts are the same. Any advice would help. Thanks!!
Harold0664 is offline   Reply With Quote
Old 04-04-2015, 01:31 PM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
They should be symmetrical.
Colin
Colin H is offline   Reply With Quote
Old 04-04-2015, 01:32 PM   #3
1971 31' Sovereign
I have an extensive construction background and maybe I'm over thinking this issue but input would be helpful. Thanks again
Old 04-04-2015, 01:33 PM   #4
1971 31' Sovereign
Ok Colin thanks. That.made sense to me so I guess I need to make them such.
Old 04-04-2015, 02:21 PM   #5
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Not to contradict Colin, but the important thing is that your new floor piece lines up with the outside edge right? So you can secure the C-channel?
I stopped making any assumptions about symmetry or uniformity on my project. It started when I re-fabbed the wheel wells. I figured they be the same dimensions...nope.
'61 Safari
http://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 04-04-2015, 06:49 PM   #6
1971 31' Sovereign
The problem therein lies. Some of the C channel when I disabled it we're not.even touching the frame and none were bolted the frame just through the plywood. It's nothing like home or mobil home construction. Seems as if there are a lot of variables in these.
Old 04-04-2015, 10:28 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Symmetrical then massage body to fit.
Peace and Blessings..
Channing
WBCCI# 30676
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
