Old 08-22-2014, 08:01 AM   #15
b_ray_p's Avatar
2002 34' Classic
Beaumont , Texas
I guess the water level is the key in the black water tank smell situation, it does seem to worse right after emptying.
b_ray_p is offline   Reply With Quote
Old 08-22-2014, 08:02 AM   #16
b_ray_p's Avatar
2002 34' Classic
Beaumont , Texas
Thanks for the idea Wayward. I'll look into that!
Old 08-22-2014, 08:18 AM   #17
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Poor water pressure problems. I don't know where you're living, but a lot of campgrounds have wells, which often have either high iron or high calcium content in the water. If you get a LOT of water spotting on your shower door you've got hard water. Quick unscientific test for iron? Put a white washcloth under a faucet and let it drip overnight. If you've got rust stains, your water has high iron content.
In either case start looking at the hose connection:
  • Inline water filter? - Changed it lately? If not, do so.
  • got a screen in the hose? Check it and backflush if needed
  • Screens in the kitchen & bathroom sink faucets? Take them out and clean them.
  • crappy water flow in the shower - get an Oxygenics shower head, you'll like it.
  • water pressure regulator going bad? (find it &) replace it.
  • White hose got green stuff growing in it (It can happen when a hose sits in full sunlight. New hose wouldn't hurt.
And to find the drain pipe for the AC look in the curbside wheel well probably in front of the front tire. It's about 1/2 inch in diameter and hangs down about 2 - 3 inches into the side of the wheel well. If ANY water is draining you'll see the drips. Again you can grow algae funk in the moist drain pan or line. Use a wet dry vacuum to encourage the clog to come out - just hold the drain line between your fingers and put the hose of the vacuum up to the opening.
Old 08-22-2014, 09:02 AM   #18
b_ray_p's Avatar
2002 34' Classic
Beaumont , Texas
Where would I find the inline water filter and the water pressure regulator?
Old 08-23-2014, 12:24 AM   #19
an inline water filter is IN LINE - on the hose. It's usually a blue cylinder about 2.5 inches in diameter and a foot long.
Internal pressure regulator. Varies with year & model. Sometimes found just inboard of where the white hose attaches to the trailer. It's often in a closet or near the water pump. You'll need a manual to find it. Airstream.com has PDF files of most of the old manuals online.
P
Old 08-23-2014, 02:01 AM   #20
b_ray_p's Avatar
2002 34' Classic
Beaumont , Texas
Thanks, no inline filter, and no white hose. Will have to look for the other.
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
