12-11-2018, 10:06 AM
DentsAndFiliform
2018 26' Flying Cloud
Wilsonville
, Oregon
Heat Pump Won't Shut Off
Hi,
We have a 2018, 26', Flying Cloud. For about a year now we've used the heat pump off and on. Last week we used it in temps that got down into the 40's at night. Before going to bed, I would manually switch over to the furnace because the furnace is quieter and heats a little better. All was good until the last night when the heat pump would not shut off. Both the heat pump and furnace were running despite anything I would do. I eventually shut off the 30 amp service and ran the furnace on battery. The next day, around 11 am when it was in the 60's, I switched the 30 amp service on and the heat pump started up again. The only way to shut it off was by turning it off on the thermostat. Bottom line is, the furnace works fine and the heat pump won't shut off.
I can have the dealer fix it but if it's something simple I'd rather do it myself.
I've been a member for a while but don't post much. Most questions are answered quite well and in a timely manner so I generally choose not to be background noise.
12-11-2018, 11:16 AM
Registered User
2016 25' Flying Cloud
Fairfield
Did check to see if you dud like I did, accidently change the fan from Auto to On. It will sound like the HP or furnace is running but they are not.
Press the fan button until it says Auto.
Matti
12-11-2018, 11:53 AM
DentsAndFiliform
Wilsonville
, Oregon
Hmmmm ... I believe I did check that but now I'm not sure. I'll have to take a look when I can hook up to 30 amp service again. It's at the storage lot now, but we are going out again in a couple of weeks.
Thanks for the quick reply.
12-11-2018, 12:40 PM
2015 27' Flying Cloud
Newberg
, Oregon
I'm confused. Turn either on or off, the heat pump, or the ac, or the propane heater through the thermostat is the only way I know of to control those items.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
12-12-2018, 10:15 AM
Washington
, Missouri
Matti
I agree as it happened to me... I fired the furnace and both would come on. Seems there was a recent last couple of months or so thread on this. It happened to me and I finally did a hard boot to OEM setting on the stat. Details are in your stat manual.
http://www.airforums.com/forums/f287...al-188534.html
Posts 8 & 12
12-12-2018, 11:58 AM
DentsAndFiliform
Wilsonville
, Oregon
Thanks, I've downloaded the manual. That should help a lot when I start messing with the stat.
12-12-2018, 04:14 PM
2015 28' International
Portsmouth
, Virginia
Before the reboot, I would check the fan Auto/On first. Cheers!
12-12-2018, 07:13 PM
Washington
, Missouri
Agreed.
I did the reboot when i was day 1 OTR on the 3wk maiden voyage and needed heat. It was only after the return that when trying to replicate the scenario that i suspected the switch to low/high from auto was likely the culprit. In fact i had to reboot a couple of times during the investigation.
Knowledge is good...lack of heat was borderline panic.
B
12-12-2018, 08:39 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
You have 4 settings on the A/C heat pump fan. Auto, lo, med, hi. You must have turned your fan setting to either lo, med, or hi. This would cause the heat pump fan to run and also allow the furnace to run.
12-14-2018, 12:42 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
In the interim you could manually open the A/C circuit breaker until you figure out the problem.
guskmg
12-17-2018, 01:37 PM
Airstream Ambassador
Jackson Center
, Ohio
Hi,
Hi Dents,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
12-30-2018, 02:12 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Yep, a easy mistake to make, fan should be AUTO and of course everything works better if you clean the air filters on the unit regularly.
