Old 10-02-2015, 02:51 PM   #1
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Heat pump and furnace come at same time
This just started to happen: If the thermostat is set on "Auto" or "Furnace" the furnace and the heat pump come on at the same time. I have to check to see if it happens on "Heat Pump" as well.
I've lived with it for a few weeks by turning the breaker for the Heat Pump off so just the furnace will come on.
Anyone else run into this? I'm not sure if it's a thermostat or the electronic controller in the heart pump that is causing the problem.
I'm on warranty, but if it's the thermostat, it would be cheaper to just replace it rather than tow a 5-6 hour round trip to the dealer.
2012 Dodge Durango Hemi/AWD
Old 10-14-2015, 03:03 PM   #2
Wayne&Sam's Avatar
Images: 21
I guess no one else had this problem. But in case some further internet surfer does, here's the solution:
The fan setting on the Dometic thermostat has to be set to "Auto" otherwise the fan on the air conditioner will come on with the furnace. I didn't see anything about this in the manual, it took a trip to a local Dometic service center to find out. They said I wasn't the only one who had this problem.
Old 10-14-2015, 04:56 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This is a very common thing. Every Dometic newer (digital) thermostat will enable the A/C fan either constantly or when the furnace kicks on, when the fan speed is set to anything other than "auto". This is not only on Airstreams.
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 07:23 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
