Old 09-17-2012, 05:32 PM   #1
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Have you modified your Refrigerator door?
I have a '68 Globetrotter and have camped out a bunch of times this summer. Our first summer really using our restored trailer. The weather has been ridiculously HOT!!! in California this year, constant 100-105 degree days. Our refrigerator stopped cooling well in such weather. I have a flush door covering the back of the fridge without venting other than the roof vent. Has anyone rebuilt their door to add a louvered vent and maybe a screen inside to keep the bugs out? Has it helped? Or is it better to just leave the door off when parked? Whatcha think?
Regards,
Randy
Randy Gates is offline   Reply With Quote
Old 09-17-2012, 05:42 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Some of the older trailers had a hole through the floor and belly pan for the bottom vent.
Old 09-17-2012, 06:09 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Vent
Randy, My '67 Safari has a floor vent with wire cloth over the opening. I have added screening material to keep the bugs at bay! There is enough air flow for the frig and that also helps with the gases venting thru the roof. I am surprised that your trailer doesn't have the floor vent. A PO may have replaced the floor and forgot to re-install the vent opening. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is online now   Reply With Quote
Old 09-17-2012, 06:49 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Our '72 had a hole through the floor and belly pan as well for the lower vent for the fridge. I wanted to avoid that in our refurb, so I took the fridge hatch door apart and brought the outside skin to a hot rod shop and had it louvered.
Name:	1015 refer hatch 02.jpg
Be forewarned though! The alclad on our í72 is quite hard, and it cracked at almost every louver. Not sure if you would run into the same problem on a í68 shell. The cracks are really hard to see though, unless youíre within a few feet of the door and youíre looking for them. They are at the bottom outside edge of each louver. When we got the door skin back, I did some experimenting with vulkum, and it will fill the crack and make it pretty much disappear completely. But Iíll wait until after we strip the clear coat before attempting any further repairs. Even with the cracks, the louvers are quite strong and will not cave in.
I have fiberglass window screen taped to the inside of the door to keep the bugs out.
Chris
Old 01-20-2013, 09:59 PM   #5
1972 31' Excella 500
Mount Vernon , Is For Lovers
refer compartment door mod
Chris[/QUOTE]
Great looking door. Has this modification had any effect on LP/fridge. use on the road?
Sylver Slypr is offline   Reply With Quote
Old 01-21-2013, 08:09 AM   #6
Minno's Avatar
1972 31' Sovereign
Not that I've noticed, but we have only used her twice so far; Sept and Oct last year. The fridge operated just fine both times.
I do have a solar powered fan (not hooked up yet) for the top of the fridge vent, so that will help with air flow on hot days.
Chris
Old 01-21-2013, 02:45 PM   #7
RGates
Decided against cutting into the door
I am going to build a cowling around the refer's element to better vent the heat up the plastic vent to the roof. I like the idea of a solar powered fan to assist during hot weather. The extreme heat of last summer literally knocked the refer out during the day, had to open up the side compartment door to vent it. Will let you know how it comes out this summer after road testing it. Where can I look at that fan? Can you recommend a website? Thanks as always!
P.S. Just got the old oven working and a new heater-Just about complete!!
Old 01-21-2013, 07:12 PM   #8
Minno's Avatar
1972 31' Sovereign
I think this is it, although I did not buy our's on ebay. I thought I got it at Camping World, but they do not seem to carry it anymore.
Camco 42162 RV Solar Panel and Fan for Refrigerator Vent on eBay!
Checked records. This is what we bought:
http://www.adventurerv.net/solar-fri...an-p-1252.html
