Old 07-25-2016, 09:30 PM   #1
1951 Flying Cloud # 7080
Campmore's Avatar
1951 21' Flying Cloud
Aurora , Ohio
Has Anyone Used a Freestanding Room AC Unit?
Need to put ac in my 51 FC , but don't want it on the roof. Has anyone tried a freestanding unit like the wynter(?)14,000 BTUunit? Seems like you could vent it out a window, and then remove it when not needed. Any thoughts? Thanks -E
Eric & Amy Rutkowski
Aurora, OH
WBICC # 7080
Always Welcoming Boondockers 10-15 minutes off Ohio Turnpike
Campmore is offline   Reply With Quote
Old 07-25-2016, 09:55 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Here's the problem with those: Since they blow room air outdide, that same air must be replaced with air that drawn in through cracks, holes and vents. Clearly, this hot outside air being drawn in cuts down the overall effectiveness a bunch.
Old 07-25-2016, 10:55 PM   #3
68Streamline's Avatar
Cerritos , California
Dual hose units are more efficient since it does not use pre cooled indoor air to remove heat from the heat exchanger.
68Streamline is offline   Reply With Quote
Old 07-25-2016, 11:10 PM   #4
1976 Argosy 26
Fair Oaks , California
I will be attempting the use of a Dometic split system designed for a sleeper cab on a big rig . It is rated at 10k BTU so it might be a little small for my Streamline Duke project . From the little bit of research I have done , my Yamaha 2000 should have no trouble running it . I have also heard that some people run it on 24 volts (two batteries) . Install is a long way off so I am just throwing out the idea.
Argosy Heir is offline   Reply With Quote
Old 07-26-2016, 05:01 AM   #5
Campmore's Avatar
Aurora , Ohio
The unit I'm looking at is a two hose unit, so it has an intake air source
Aurora, OH
WBICC # 7080
Old 07-26-2016, 05:35 AM   #6
1989 34.5' Airstream 345
Ebro , Fla Panhandle
I'm using one now while pet sitting at my sister's place.
This is my first time using this sort of unit. While it does help cool the room somewhat, it seems to be fight itself in the process. This one is a single hose model, so may not be the best example.
A lot of heat radiates off the back of the unit into the space being cooled reducing its effectiveness, plus this one is quite noisy.
After checking this one out for a few days now, I'm thinking a window mounted unit would allow most of the heat and noise to be vented outside.
I realize the effort of mounting it and the look of one hanging in a window is not appealing. But probably a better way to go for comfortable cooling.
Cheers Richard
tevake is offline   Reply With Quote
Old 07-26-2016, 05:41 AM   #7
Long Island , New York
With a window AC the hot part of the unit is already outside. That is why they are popular and fairly efficient.
Using this kind of unit inside a room is very inefficient.
Old 07-26-2016, 11:46 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
These free standing a/c units don't cool as well as window units, split systems, or roof a/c units.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-26-2016, 11:50 AM   #9
Grosspoluter's Avatar
Franklin Park , Illinois
AC Stand alone
I've used a stand alone unit on my camper (Some Other Brand)
And I thought it worked ok
Grosspoluter is online now   Reply With Quote
Old 07-26-2016, 11:58 AM   #10
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I'm installing a 14K BTU portable as a second A/C. I would say that it works almost as good as the 15K Dometic DUO THERM Brisk II in the roof. I have a separate 30A electrical feed (with cord) for it. So when I want to run both A/Cs, I plug a Y-connector into the 50A plug, and run twin 30A cords to the trailer.
My Dometic is being replaced under warranty as I write this, so I haven't yet tried the whole thing out. I could easily see using twin portables, and not having to deal with that ugly unit up on top. But then I'm a campground guy, not a boondocker...
I know what tevake means about radiating heat. I got some 6" A/C insulated ducting to wrap around the exhaust hose. I removed the propane furnace vent, and custom fabbed up a grill for it.
Hopefully this weekend I'll be the coolest cat in the campground!
SuzyHomemakr is offline   Reply With Quote
Old 07-26-2016, 12:32 PM   #11
1977 31' Sovereign
Lynnwood , Washington
Be cautions of BTU output. You'll be drawing a lot of amperage.
I don't think the wiring in your 1951 Flying Cloud was ever intended to handle that kind of load.
Tom
TomKirk is offline   Reply With Quote
Old 07-26-2016, 01:44 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I use a window air unit in my 66. It is a method of installation a long time member here sent me. I use a small wooden folding snack table, cut down the front legs. The unit goes over the window edge in front, sits on that edge and the propane tanks. Solid.
I use heavy clear plastic bought in a roll at HD. Cut a surround from it and that is velcro-ed to the wall inside. Keep the hot air out and the cooler air in.
Works great, but I am not 100% happy with the cool air blowing in over the gaucho where we sit.
Cost me $35 for a slightly used unit and the plastic...and cools the trailer in most hot weather, though not in upper 90's and sunny.
I wold prefer a split unit but too pricey for us right now.
Smokeless Joe had the best unit I've seen in person. Loved it
Name:	AC on Overlander.JPG
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 07-26-2016, 01:59 PM   #13
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
I have a stand-alone AC unit "built" into the rear cabinetry of our Bambi II where the LP furnace used to be. I re-did the furnace exhaust vent and vented it that way...no one is the wiser. It stays put because I built the cabinetry to hold it snug while underway.
It is moderately effective. It will not cool the trailer if it is sitting in direct sun. The inside just gets too hot and it can't keep up. It is a single hose version, so the sucking in of hot air already mentioned does play into it.
On the other hand, it is effective if the trailer is shaded and will freeze you out at night (when we use it/appreciate it most...for sleeping).
We are usually not in the trailer on hot days...we are sightseeing, hiking, swimming, road tripping, or otherwise. The trailer is our home base away from home, and so the AC unit does what we need it to specifically do.
If we had it to do over again, I would look for a two hose unit, but we bought our current one used from a co-worker for cheap.
ID:	267751   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 07-26-2016, 02:07 PM   #14
LongShot's Avatar
2015 19' Flying Cloud
Ashland , Kentucky
Images: 8
You may also want to consider the Climax Air dual-hose unit; it uses DC inverter technology and is actually significantly more efficient than window units. Of course, there is a substantial investment up front, but . . . . To help with your research:
http://www.climax-air.com
One Long Shot
Beastie - 19'FC
The Big Beast - GMC Yukon w/Max Tow Package
Held together with the Husky Centerline Hitch
LongShot is offline   Reply With Quote
Has anyone used a Carefree Vacation'r Screen Room? mrdfred Airstream Lifestyle 12 03-13-2016 08:21 AM
Has anyone hidden an AC unit? rivetsforlife Furnaces, Heaters, Fireplaces & Air Conditioning 18 02-20-2015 08:19 PM
has anyone ever built a airstream style guest house or room coastal Airstream Lifestyle 8 02-13-2014 08:59 PM
Freestanding LP Stove with Piezo Ignition VAbirdwoman Stoves, Ovens & Microwaves 1 07-31-2012 08:44 AM
How to Anchor a Freestanding Stove? ironfem200 Stoves, Ovens & Microwaves 1 12-20-2006 04:51 PM
