Old 07-31-2014, 10:57 PM   #1
Wishing's Avatar
2014 27' FB International
Clovis , New Mexico
Has anyone had a leak repaired at Camper Clinic II?
Just discovered some major leaking (right in between the emergency exit window and left side of the pano in the FB) during a rain shower...the closest large airstream dealer is Camper Clinic II. How are they on their repairs-especially on the aluminum skin. Or is this something I need to take care of at the factory?
Wishing is offline   Reply With Quote
Old 07-31-2014, 11:14 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
They are an AS dealer.... As such, may be interested in helping fix the leak. Perhaps that way it will be "documented". Some folks may say "don't waste your time, AS won't stand behind the warranty"...but I would give them a chance.
Hope it works out!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-12-2014, 02:25 PM   #3
Jim J's Avatar
2014 30' Flying Cloud
Images: 117
They can be hit or miss.
Jim J is offline   Reply With Quote
Old 08-12-2014, 10:56 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Result?
Channing
WBCCI# 30676
Old 08-13-2014, 08:09 PM   #5
Rot-Roo Rastro!!
silversled's Avatar
2000 30' Limited
Never hit or miss for us. Always a miss. I would rather drive to Dallas or Ohio to get the repair done. Good Luck if you go.
Astro & the humans I train Barry&Andrea
2000 Airstream Limited 30' ~ Silversled
2005 Ford Powerstroke, 4X4, Crew Cab
AIR #12075
silversled is offline   Reply With Quote
Old 08-14-2014, 12:39 AM   #6
Wishing's Avatar
Clovis , New Mexico
Silversled-where in Dallas do you go? Is it Vogt RV? I actually repaired the leak (cracked sealant on top of the emergency window), but I'm having other issues I wanted to fix.
Old 08-14-2014, 08:31 PM   #7
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Don't Waste Your Time With Them
I've had negative experiences with 3 Airstreams, also saw something very disappointing that a Technician did as I pulled away with our Airstream. To make matters worse, they have a disrespectful employee that schedules appointments. If you do it, you're taking a risk.
Frank&Mike is offline   Reply With Quote
Old 08-14-2014, 09:03 PM   #8
Goal15's Avatar
Dallas , Texas
North Dallas RV at 35E and PGB Turnpike. They always have a lot full of AS being worked on. Only negative I've heard is that they can sometimes take a long time to start on a project. Look up Top here on AIR Forums. He's down near Kileen and people have reviews his work very favorably
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Has anyone removed/repaired/replaced a shower pan? AFUser Sinks, Showers & Toilets 4 04-12-2014 10:50 AM
Patio light leak repaired Alphonse Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 12-06-2012 05:54 PM
Has Anyone had this problem? jjustice Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-02-2011 11:15 AM
Has Anyone Else Had a Bear Climb In Their Airstream? cclarkego Off Topic Forum 117 01-17-2011 09:30 PM
Has anybody repaired a Cunningham toilet? ddstech Sinks, Showers & Toilets 0 08-22-2010 12:19 AM
