Old 06-27-2014, 05:13 AM   #85
r carl's Avatar
Lin , Ne
I bought a roll of sandpaper for a DA sander at HF and all the grit would come off in 2 sec. of sanding. I couldn't believe it.
Old 06-27-2014, 06:42 AM   #86
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
I've been there: 1959 Airstream Overlander, "Someday": We Didn't Prepare For This
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 06-27-2014, 06:52 AM   #87
3202 Ellie
boliversr's Avatar
1975 Argosy 24
milan , Michigan
I have no problem with HF but pick and choose what I buy my heavy use tools are all high quailty
boliversr is offline   Reply With Quote
Old 06-27-2014, 07:03 AM   #88
Tincampers's Avatar
Sneedville , Tennessee
It's just like buying anything anywhere. You need to do some research and use some common sense. Not everything they sell is junk nor is everything top notch. I've had bad luck and good luck there. The bad luck stuff goes back for a full refund.
Tincampers is offline   Reply With Quote
Old 06-27-2014, 07:35 AM   #89
Taylormade's Avatar
1978 31' Sovereign
Yeah their sandpaper is absolutely a joke. Sometimes they have 3M sandpaper though, and that holds up a lot better. Whatever their branded stuff is isn't good for anything.
Ut Prosim
Taylormade is offline   Reply With Quote
Old 06-27-2014, 10:00 AM   #90
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Stopped the SnapOn truck yesterday and acquired their tire lug nut specific (5 pound increments) torque wrench for around $375 with tax. Is not designed to loosen those nuts.
Old 06-27-2014, 11:59 PM   #91
Matthew014's Avatar
2004 25' Safari
Cumming , Georgia
LOL, no torque wrench is designed to loosen lug nuts (or any nuts). It obviously can be physically done, but it's a really good way to throw it out of calibration.
Matthew014 is offline   Reply With Quote
Old 06-29-2014, 12:10 PM   #92
r carl's Avatar
Lin , Ne
Can you torque in both directions with it?
Old 06-30-2014, 05:23 AM   #93
switz's Avatar
2014 31' Classic
Images: 8
Clockwise only.
Old 06-30-2014, 05:32 AM   #94
r carl's Avatar
Lin , Ne
I have 2 SnapOn torque wrenches and they have a direction lever in the head, so if they are one way, what's the lever for?
Old 06-30-2014, 05:35 AM   #95
switz's Avatar
2014 31' Classic
Images: 8
No direction lever on wheel lug nut only wrench. It is calibrated in five pound increments. The reversible torque wrench probably has the one pound increments.
Old 06-30-2014, 05:44 PM   #96
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have had vehicles with reverse thread lug nuts, seem to recall it was an old Dodge for some reason. Fan clutch on my 96 F350 is reverse thread.
Might just need that left handed torque wrench and not even know it.!
Aaron
WBCCI #XXXX AIR #2495
Old 06-30-2014, 06:09 PM   #97
r carl's Avatar
Lin , Ne
I had a 1967 F350 and the left side wheels had left hand lug nuts.
Old 06-30-2014, 08:04 PM   #98
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Older trailers and vehicles with lug bolts (not nuts) had left hand thread on the right side of the vehicle and right hand thread on the left. The idea was, they would not unscrew whilst traveling. The head of the bolts had and "L" or "R" to ID the thread rotation.
Harbor freight polishers? lewishw Cleaning, Stripping & Polishing 53 01-23-2013 12:54 PM
Cheap LED Tailight conversion at Harbor Freight? ronstory Lights - Interior & Exterior 4 07-25-2008 05:41 AM
Harbor Freight has a sale on 45W solar array bobechs Generators & Solar Power 10 07-11-2005 08:20 PM
Harbor Freight = Hubby's Heaven ! Herm and Debby 1970-79 Tradewind 2 12-20-2004 06:04 PM
Harbor Freight Buying Tip... malconium Commercial Listings 19 09-09-2004 05:22 AM
