Old 04-30-2014, 08:32 PM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hand crank for stabilizers?
Totally noob question here - but what the heck is the name of the hand crank tool that you use with the stabilizers on the trailer (in my case, a 2012 27FB Flying Cloud in case they're different from year to year or trailer to trailer).
The one that came with the trailer didn't last more than a few trips. The head wasn't permanently affixed and fell off. I'd like to replace it with something similar but MUCH sturdier but I don't even know what name I'm searching for (or size for that matter - it's the same size as the WD jacks on the ProPride - that's another reason I want to replace the tool - was using an impact wrench to raise/lower those and broke the roll pin inside one of the jacks! )
Thanks in advance for your insights and alternatives if you have suggestions. Thanks!
Old 04-30-2014, 08:37 PM   #2
dznf0g's Avatar
Oswego , Illinois
Um, jack hand crank, I guess. Not sure what cost comparison is, but tool mfrs, like Craftsman make a speedy driver that takes sockets...3/4" in this case. It's kind of a blast from the past. I bought one when I was in automotive school, but everybody uses power now. I assume they still make them.
-Rich-
Old 04-30-2014, 08:42 PM   #3
dznf0g's Avatar
Oswego , Illinois
Here you go:
Speeder Wrench from Craftsman.com
-Rich-
Old 04-30-2014, 08:49 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Harbor freight has the speed wrenches in ⅜" and " drives as well at much lower cost than Craftsman or Snap-On. I got a deep well socket as the shallow ones tend to come of when really cranking on the on post jacks on either the Hensley or ProPride jack stands.
Old 04-30-2014, 09:06 PM   #5
W , New England
Great. Thank you muchly!
Old 04-30-2014, 09:35 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Are you out of the two year warranty?
Doug and Cheryl
Old 04-30-2014, 10:28 PM   #7
2004 16' International CCD
Chicagoland , Illinois
If you need more selection you might try etrailer.com
Replacement Handle for Scissor Jacks (BAL-24SJ) Redline Accessories and Parts BAL-24033
Crank Handle for Stromberg Carlson Scissor Jacks and Tongue Jacks Stromberg Carlson Accessories and Parts JCH-1
Airrogant is offline   Reply With Quote
Old 05-01-2014, 04:20 AM   #8
W , New England
No, but the tool was junk and replacing it with junk doesn't make sense to me. The Craftsman one dzn posted (with a deep hardened socket) looks like a better solution for me.
Old 05-01-2014, 04:21 AM   #9
W , New England
Thanks Switz and Airrogant.
Old 05-01-2014, 05:26 AM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can always get the adapter to go in a cordless drill. It is so much better than the hand crank.
Old 05-01-2014, 05:35 AM   #11
andreasduess's Avatar
1984 34' International
Toronto , Ontario
That's what I do - use a cordless drill. Also makes cranking the Hensley so much quicker and easier.
Make sure to select the right setting on the torque selector of the drill so the stabilizers don't accidentally slam into the ground and start lifting the trailer.
andreasduess is offline   Reply With Quote
Old 05-01-2014, 06:47 AM   #12
1981 31' Excella II
New Market , Alabama
I have been using a cross wrench for taking off lug bolts. It works well and you can spin the wrench and it is much easier than the dog leg crank thing. I have the crank but I use the cross wrench. No need for a drill with a cross wrench. This is assuming your jacks are lubed and in good shape. I am also assuming a standard Bal Jack with the nut on the end of it.
Perry
A-Frame Jack, front-facing hand crank? Splitrock Jacks, Stabilizers, Lifting and Leveling 5 04-19-2011 07:31 PM
Cleaned up my BAL stabilizers... Sneakinup Jacks, Stabilizers, Lifting and Leveling 0 04-27-2004 05:29 PM
BAL stabilizers losing nuts? Kistler Jacks, Stabilizers, Lifting and Leveling 3 04-15-2004 06:50 PM
BAL Stabilizers kamadeca Jacks, Stabilizers, Lifting and Leveling 1 11-28-2003 12:32 PM
