05-14-2017, 02:09 PM
2016 26' Flying Cloud
Oxford Mills
, Ontario
Half threaded 2 inch Bolt ?
We returned from our Eastern Ontario Shakedown this morning and after parking Lucille in her spot I found this / inch half threaded Bolt on the ground just under the toungue ? Thoughts.....
05-14-2017, 04:46 PM
2007 30' Classic S/O
Somewhere
, South Carolina
That is called a Carriage Bolt, round head and square under the head. Almost always used on wooden construction, picnic tables etc. Very doubtful its from your rig.
05-14-2017, 04:49 PM
Oxford Mills
, Ontario
Ty, I will check all our tables/chairs etc ....
05-14-2017, 05:18 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
It's also stainless steel. Not an airstream bolt.
05-15-2017, 10:59 AM
Classy Roscoe
Sometimes those bolts are used on assemblies that hold hose clamp like straps.
But, I have also seen them used to hold aluminum patio furniture tubing and chair arms to the frame.
Might look carefully to see if the bolt has ever been used. The threads will be slightly distorted.
Otherwise it is a Russian plot to make you worry.
Have a wonderful summer.
05-15-2017, 05:56 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
How do you figure a "Stainless Steel Bolt"?
Usually a carriage bolt is made of Grade 1, or Grd.5 steel, and Cad. plated.
I don't ever recall ever seeing a S.S. carriage bolt.
Stainless Steel usually have a kinda 'greyish' appearance, not shiny silver. (cad. Plated)
05-15-2017, 08:56 PM
2013 25' Flying Cloud
Wheaton
When I put a magnet close to the picture of the bolt, it wasn't attracted to it.
05-15-2017, 09:15 PM
1995 25' Excella
xxxxx
, xxxxxx
Somebody chucked it under your trailer to drive you nuts.
I used to do similar to my buddy's newest bike every time he got one.... A couple of drops of oil on the pavement out of an oil can is great entertainment... Lol
05-15-2017, 09:32 PM
1999 34' Excella
Hillsboro
May be aluminum... or "pot metal"... cheep stuff .. don't know where you park... but if not in private secured area, all bets are off. I often found "surprises" in our public storage where folks just tossed hardware, beer cans and other stuff around....
If it doesn't have road rash then someone just tossed it.
Peace and Blessings..
Channing
WBCCI# 30676
05-16-2017, 06:32 AM
Blenheim Ontario
, Ontario
Try putting the magnet close to the bolt itself, instead of "the picture". I ' wager that it will attract to the bolt.😄
05-16-2017, 07:13 AM
Louisville
, Kentucky
Propane bracket bolt?
05-16-2017, 09:52 PM
2008 23' Safari FB SE
Parnell
, Iowa
There are stainless steel carriage bolts. Have some. Use in corrosive environments. Doesn't look like anything from the front of an airstream stainless steel or not.
05-17-2017, 12:57 AM
Mantua
, Ohio
Looks like the bolt I use to hold the hitch clasp, runs through the hole with a nut on it.
05-17-2017, 01:57 PM
Blenheim Ontario
, Ontario
Interesting! Learn something new everyday😄
