Old 07-05-2016, 04:10 PM   #15
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Its kind of funny that of all people to rain on your parade it would be me, a motorhome guy..........None of you trailer people told him about this.
Renovating a trailer is more science than design. It's the reason most people get to the stage you are at, and then give up, for the simple reason......they forgot to section off their trailer and weigh everything that comes out of the sections. How else are you going to know what weight you can put back, and where. Now you're going to have to science the crap out of this.
Find the Airstream stock weight, empty and gross weight full of your trailer. Section off the trailer into four sections (two equal ahead of the axles and two equal behind); and weight everything that goes into these sections If you can, add a middle line to weigh side to side. You will also need a weigh scale under the tonque to set tongue weight.
Whatever cabinets you make will have to be as light as possible. Mine I made for my motorhome have no bottoms, backs or even tops, other than countertops.
Remember to add everything that you intend to go camping with into whatever section you will need to store it in. If you create a lot of storage far behind the axle, while empty the tonque weight will be fine, but fill the storage full and all of a sudden your tonque weight could be negative (very, very bad thing).
Good luck
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-05-2016, 05:02 PM   #16
Central , Mississippi
Gutted airstream unsure of where to start!
New floor covering always makes me nervous. It's really easy to cover up a poor job of subfloor repair. I'd suggest that now would be a perfect time to see if your trailer has a good, solid, properly installed subfloor prior to moving forward. My '63 had the front 6-8' of floor replaced sometime in its past BUT they didn't attach it properly to the C channel and out riggers. The result was if you grabbed the front edge of the door opening, the entire wall would slide in and out.
On edit-welcome to the '60's club!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Unsure about Range Rover as Tow Vehicle Kay Hitches, Couplers & Balls 11 01-13-2017 07:30 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
AIRSTREAM 1967 Airstream Ambassador 28 ft GUTTED! Ready for your remodel!! eBay Watch Airstreams on eBay 0 10-21-2011 06:00 PM
Unsure of Restoration??? help! ELIZ11356 General Interior Topics 4 05-23-2009 01:17 PM
