Old 04-27-2016, 07:53 AM   #1
KSA63's Avatar
2011 28' Flying Cloud
Ramara , Ontario
Green Spot on Clear Coated Panel.
I found this green spot in front of the BR window on the right side of our trailer. I have tried everything from mild cleaning solution to polish and a medium cut abrasive to get rid of it but nothing is having any affect and I do not want to cut into the clear coat any further. Has anyone seen such a stain before and have any ideas how to remove it? It looks like it may actually be in the aluminum beneath the clear coat.
A dime would just cover the spot and it is not a huge problem but I would like to know what it is.
Green Spot
Kevin
KSA63 is offline   Reply With Quote
Old 04-27-2016, 08:07 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have no idea what might have caused that, but judging by the picture it seems like that it is in the metal and not the clear...
Maybe a good place for a decal?
I might speculate that the aluminum in that spot might have suffered some chemical contamination prior to being clear coated that has since become active?
Superat stultitia.
Old 04-27-2016, 08:12 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The only other thing I can think of that might cause that is the metal being made hot by an electrical short or arc against the skin. (Inside the wall)
I would more likely think my first guess than my second guess.
Superat stultitia.
Old 04-27-2016, 02:31 PM   #4
KSA63's Avatar
Ramara , Ontario
I think that you are correct, this green stain is not on the surface and was likely created from a flaw or impurity of some sort. Its not a big deal but would be nice to clean it up. I do not believe I have an electrical problem.
Thanks for the responses.
Kevin
Old 04-27-2016, 02:35 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have had spots like that, it is aluminum alloy corrosion. Easy enough to remove with a pencil eraser. Only a temp fix, it comes back.
MICHAEL
Sources of 'factory' clear-coated aluminum? Belegedhel General Interior Topics 34 11-30-2014 10:15 AM
water tank in '62 Ambassador/are tanks coated inside? SANTINO MARC Fresh Water Systems 1 01-19-2010 09:32 AM
Pre-coated Alcoa aluminum panels idahosafari Ribs, Skins & Rivets 4 12-06-2004 04:33 PM
Painting the vinyl coated... geof Upholstery, Blinds, Walls & Interior Finishes 1 04-28-2003 10:37 PM
