Old 01-23-2009, 07:40 AM   #1
Muncie , Indiana
Great drill depth stop
Last Monday I took my new (to me) AS to the factory service center for the refrigerator recall and took the tour while I was there. Very interesting and well done. The guide showed us a tool they use that I thought was great.
I’ve often used electrical tape on a drill bit to mark the depth of a hole I wanted to drill. I’ve also just pushed the tape up and drilled too deep. The tour guide showed us a drill and what they use for a positive stop. They had the bit in the chuck of the drill and put a piece of bare copper wire beside the bit and between two of the chuck jaws. They then bent the wire over 90 degrees and started to wind it around the bit. Next they held the wire taut and started slowly running the drill to wind the wire snugly around the bit and kept going until they had only the length of the bit exposed that they wanted through the material. It gave a very positive stop that wouldn’t get worn away with a series of uses and by winding it with the drill running forward, it wouldn’t catch when it got to the surface. The end product looked like a spring in case you're having trouble visualizing. The trimmed end could be dressed with a file to smooth it and reduce any surface marring.
Probably old news to some but hopefully will help others.
SailorSteve is offline   Reply With Quote
Old 01-23-2009, 08:46 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
These work well also
Drill Stops
Old 01-23-2009, 09:01 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Thanx for the tips. I always like being aware of things like this.
Brian
SuEllyn & Brian McCabe
Old 01-23-2009, 02:35 PM   #4
345bill's Avatar
Las Vegas , Nevada
I second what moosetags said, Thanks!
345bill is offline   Reply With Quote
Old 01-23-2009, 03:13 PM   #5
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Drill Stops
Never seen those, maybe I'm dense today but how do they work?
On edit, I got a larger photo - I see how it works. Looks handy.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 01-23-2009, 07:15 PM   #6
2005 22' Interstate
Afton , Virginia
For years I've used corks from wine bottles to stop the drill bit from going too deep. Chuck the bit in the drill motor, put the cork in a vise, drill through the cork. If one is not enough, use another and cut it to depth. It's really easy now that they use synthetic corks.
regards
herrgirdner is offline   Reply With Quote
Old 01-23-2009, 07:53 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Great Tip
Thanks. I have always used tape, so I know what you are talking about. It does blow away any sawdust in wood, though.
Vaughan
Old 01-24-2009, 12:45 AM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have been drilling holes in brand new cars since 1968 and the best drill stops were made from rubber vacuum, or fuel hoses. They are cheap, cut to any length you want, and won't damage paint.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
outlet box depth tinbender Batteries, Univolts, Converters & Inverters 10 02-27-2008 07:04 PM
In beyond my depth! jking Classic Motorhomes 5 09-01-2006 12:23 PM
Drill a hole Chuck Ribs, Skins & Rivets 17 05-31-2005 04:26 PM
drill size? Stormy Weather Ribs, Skins & Rivets 18 10-17-2004 12:57 PM
