Old 02-29-2016, 08:09 PM   #1
Raleigh , North Carolina
Gray water drain?
I'm the new owner of a 1969 21 Globetrotter. My first travel trailer. I'm also on my first camping trip.
When dry camping, the gray water from kitchen backs up through the shower floor. I don't have a gray water tank, only a black water tank.
The drain piping from sink and shower lead back to the same place where I dump the black water tank, but it does not appeared designed that the the gray water would go into that tank.
I emptied the black water tank to see if gray water would flow into it, but the sink water still came right up through the shower drain.
Is there something I'm missing here?
should there be a separate valve that lets me drain gray water onto the ground or in bucket? If so, I can't find it.
Any guidance would be much appreciated.
Mark
Mwkelley is offline   Reply With Quote
Old 02-29-2016, 08:23 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You will need to remove the termination cap, and let the grey water drain into a purpose-made portable tank, or into the sewer connection at the campsite if there is one. I am pretty sure it is illegal in all 50 states to simply dump grey water onto the ground.
Old 02-29-2016, 08:33 PM   #3
Thanks for heads up on law.
The termination cap, where would I look for it? Perhaps need to remove a section of belly?
Old 02-29-2016, 08:42 PM   #4
cameront120's Avatar
1972 25' Tradewind
The grey water and black water drain out of the same dump valve. Should be located at the rear of the trailer. Go here and download the PDF manual for 1969, then go to part 9 and read that section on the sewage system. Should have everything you need.
https://www.airstream.com/service/ma...ear_select=877
North Vancouver, BC
Old 03-01-2016, 09:21 AM   #5
Thanks for the insight and link to manual.
Turns out plugging the bathroom drain allows sink gray water to flow into the tank.
Old 03-01-2016, 10:35 AM   #6
1972 25' Tradewind
Yes, that's exactly what it does. Learned it the hard way with my own trailer the first time I used it. Get yourself a blue boy tote and you'll be all set.
North Vancouver, BC
Dish Water, Shower Water, Gray Water... nvestysly Boondocking 63 10-26-2016 01:21 PM
Can you urinate in shower with gray water drain open? JoePaCO Full-Timing 65 08-21-2014 12:02 PM
Gray Water Tank Slow Drain extiger Waste Systems, Tanks & Totes 14 05-11-2010 09:17 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
