Old 06-26-2016, 01:42 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Good Grief!!! 1150 lbs of Tongue Weight???
Just weighed my tongue with my new Sherline Scale:
1150 lbs.
You've got to be kidding me, there is almost nothing in the front of the trailer.
Specs say it is supposed to be 885 lbs. with batteries and propane.
This is too much on my truck, I have a 2015 30' Flying Cloud Bunk.
What can be done?
Ted S. is offline   Reply With Quote
Old 06-26-2016, 01:54 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
1150 lbs.
What can be done?
Remove one battery (40#) and one LP tank (50#), and tow with no water in the fresh tank, and don't put as much stuff under the bed in the front.
Old 06-26-2016, 01:57 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
1150 lbs.
What can be done?
(1) Calibrate the scale by weighing an already-known weight to see if the scale is accurate. Do this at least twice, with different weights.
(2) Shift portable trailer contents to a position behind the axles, the farther back, the better. Everything you add forward of the axles increases tongue weight, and the farther forward, the greater the effect.
(3) put the trailer spare in the tow vehicle to get it off the trailer.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-26-2016, 02:04 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Empty the wardrobes, too? ;-) Tell the bride the shoe collection has to stay behind? On second thought, it is probability safer to just upgrade from a 1500 to a 2500 HD.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 06-26-2016, 02:11 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
You said NEW. Can we assume the trailer is empty and if not what are you carrying and where is it loaded?
2004 Excursion 4x4
Old 06-26-2016, 02:11 PM   #6
Mach5's Avatar
Woodland , California
You must have charged your batteries full up...
But seriously, I don't think anyone on this forum is going to be able to suggest a general repair to fix your tongue weight. You may want to post over on the Flying Cloud specific trailer forum:
http://www.airforums.com/forums/f516/
They may not be able to solve your issue either, but at least they can sympathize with your plight and suggest alternatives.
Mach5 is offline   Reply With Quote
Old 06-26-2016, 02:39 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Add ballast to the rear?
Old 06-26-2016, 02:47 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Have all passengers ride on the AS bumper. Easy.
2012 Dodge Durango Hemi/AWD
Old 06-26-2016, 02:48 PM   #9
Gainesville , Florida
It's too easy to overload a trailer by adding additional weight to the rear. Be careful. High tongue weights require real tv.
Old 06-26-2016, 02:49 PM   #10
Wayne&Sam's Avatar
Images: 21
You're not using a weight ditribution hitch?
Old 06-26-2016, 02:54 PM   #11
2015 30' FB FC Bunk
We are in-between trips. The trailer is barely loaded. I have a Propride, so that must be part of it.
Old 06-26-2016, 02:59 PM   #12
Well Preserved
1993 21' Sovereign
The ProPride is roughly a couple hundred pounds, so that would be part of it.
Old 06-26-2016, 03:03 PM   #13
It also will distribute some of the weight.
Old 06-26-2016, 03:12 PM   #14
1973 31' Sovereign
Middletown , California
Crank up the WD bars a bit more and just be sure you don't exceed the tire rating of the rear axle. Maybe add air bags to boost rear spring capacity. Load the stuff from the truck bed to the rear of the trailer. That's about all you can do except get a bigger truck.
ijustlee is offline   Reply With Quote
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Good grief... another trailer's saggy rear laducky Repairing/Replacing Floor &/or Frame 7 12-29-2014 05:15 PM
Good grief, about to go FT!! lebolewis Full-Timing 41 10-30-2014 03:57 PM
Anyone towing 27FB (7,600 lbs / 770 lbs tongue) with a V8 or TDI Touareg ? Timofeevich Tow Vehicles 41 09-23-2011 05:55 PM
Good Grief! What have we done? ND10CentCan Exterior Restoration Forum 32 03-23-2011 03:44 PM
