Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-04-2008, 03:21 PM   #29
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
Gilbert,
That axle installation looks great. You might be able to recreate that vent yourself, or have a local tin shop (heater duct place etc) recreate it since they have the bending tools. But I'd be tempted to try it myself, after I first tackled restoring the old one. With some patience and thought I'm sure that one could be tapped back into it's original shape.
Thanks for sharing the update photos. I guess now you have to go find out where that darned puppy buried the old axle set up.
Keep us posted on your next project.
Barry
The best things in life are health, family, friends and enjoying your Airstream in a campground. Wally on Bro
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
AIR #7364 WBCCI #8110 member 4CU
safari57 is offline   Reply With Quote
Old 01-15-2008, 11:29 PM   #30
2bkidfree
Profile:  1959 22' Flying Cloud
Escondido , California
Fake oven vent.
Well, I removed the crushed oven vent to try to fix it and guess what I found. The crushed oven vent had a piece of aluminum riveted to its back. The opening in the side of the trailer also had a piece covering it's inside skin. I know the vent worked at one time because I can see the steam/heat marks on the trailer. I can't see the inside wall portion of the vent because it's blocked by the oven. Anyone have any ideas why the PO would've done this and is it a problem? Seems to me that venting an oven is a good thing.
I'm posting pictures of what I found.
Name:	Crushed oven vent.jpg
ID:	52580   Click image for larger version
Name:	false oven cover.jpg
Name:	false oven vent.jpg
2bkidfree is offline   Reply With Quote
Old 01-16-2008, 10:42 AM   #31
Zeppelinium
Registered User
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
From the photo up in your post #28, it looks like the vent is just below the countertop. Maybe some PO had coal stove and needed a vent!
Modern ovens don't need a vent like that. The hot air comes out the slot behind the stovetop and is usually vented up at the overhead cabinet level by a fan. I think it's OK that your "vent" is covered over.
The only real use for that vent is if the PO had a fan of some sort that was right next to the oven's vent slot and aggressively ejected the hot air. This would only be "practical" if the trailer had been used a lot in cold weather and humid climates--it might have eliminated a lot of interior condensation. But it would also have sucked cold air in through every leaky window and door seal.
The only reason for this vent would have been a wood burning stove.
Zep
Old 02-19-2008, 10:32 AM   #32
2bkidfree
New propane rack and paint
Well, I finally got the new propane rack mounted and painted. My neighbor used his new welding unit and it was really cool. He used to lug over his huge welder, but now he has this James Bond type unit. It comes in a brief case and works on either 120 or 240v. It's from Miller.
I also painted the front and found out something. I used Por 15 and it worked nice, but the Sterling Silver top coat took forever to dry and never developed the hard coat that the Por 15 did. It can scratch and rubs off. I called the mfg. and they said that is how it comes out.
I also have been working on the interior and figured out how to get the 12v working, the 120 works as well as the propane lamp (it just doesn't put out much light). The heater and stove work, but he fridge is shot.
If anyone has an interior propane light that works, let me know how much they put out. The guys as the VAP said that I probably need to replace the propane lines (they're probably right). 49 years can lead to a lot of build up.
I'm including pics of the work. BTW the 2x4 at the front is there because someone came really close to "Can Opening" the side of their car so now everyone can see where the trailer ends.
Gilbert
Name:	Propane rack welding.JPG
ID:	54630   Click image for larger version
Name:	Propane Rack 2.jpg
Old 02-19-2008, 02:18 PM   #33
Zeppelinium
Registered User
1977 23' Safari
1975 31' Sovereign
Originally Posted by 2bkidfree
...I also painted the front and found out something. I used Por 15 and it worked nice, but the Sterling Silver top coat took forever to dry and never developed the hard coat that the Por 15 did. It can scratch and rubs off. I called the mfg. and they said that is how it comes out.
In my experience, most silver or aluminum paints are like that, very fragile. On the other hand, I used Rustoleum aluminum spray cans to redo my tanks, and although they show rub marks, the paint has remained on without flaking.
Zep
Old 04-19-2008, 07:01 PM   #34
2bkidfree
New door Lock
Well, I couldn't find a Bargman L-77, so I converted a horizontal Bargman L-66 to work in a vertical configuration. Took longer than I would've expected, but it acutally works. I'll post more details and pictures on how I did it under the Door Locks forum later. For now here is a picture of it with the dead bolt I also added.
Gilbert
Name:	New Door Lock - web.jpg
Old 04-19-2008, 08:43 PM   #35
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Here's a pic of our LP lamp. It was broad sunny daylight when I took this photo:
Old 04-19-2008, 09:24 PM   #36
2bkidfree
LP Light
Mine must have muck in the propane line because yours is much brighter than mine. I wonder how you clean out a propane line or do you have to buy a new one.
Gilbert
Old 04-20-2008, 07:29 PM   #37
jeffsmattson
Profile:  bradford , Vermont
Spare Wheel
I just bought a 62 Bambi. I am looking for a spare wheel. Where is the best place to find such a thing? I have put new tires on the trailer but it has no spare.
jeffsmattson is offline   Reply With Quote
Road Trip of a Lifetime Airstream Marketing Our Community 0 02-01-2006 03:41 PM
CO to LA road trip WolfSong On The Road... 1 06-11-2005 11:49 PM
Road Trip jim8860 On The Road... 0 06-07-2005 08:07 AM
Seen on Road Trip to SW silver 67 On The Road... 0 01-30-2005 07:43 PM
