Old 04-13-2010, 12:02 PM   #1
2009 31' Classic
La Quinta , California
Question getting started again
My 31 ft Clasic has been stored for the last six months in a tempeture controled storage facility. I drained the water, grey water, black water, and drained the water heater.
I am getting ready to travel to Alaska for the summer and want to make sure I do thing right....
First of all I noted my batteries were dead.These are the ones that do not need be filled....Will they charge up as I connect to my truck?
Re the water heater, will it aukltomatically refill when I connect to a sourse and/or fill the water tank.
Any other thoughts
Mike Kline
La Quinta, CA 92253
mkline@dc.rr.com
Mike Kline is offline   Reply With Quote
Old 04-13-2010, 01:30 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
On your battery,I would use a battery charger,or plug in the trailer to let the converter charge,the TV charges kinda slow,I would want to know if the batteries are good before hitting the road.
Your WH will fill,just open a hot faucet to let the air out. Dave
easyride is offline   Reply With Quote
Old 04-14-2010, 07:23 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would use the converter or portable charger to charge the batteries. Then I would unplug the trailer from the AC power source and use the 12V lighting to see how long the batteries last. They might last for days but it could be just a couple of hours. It might be hard to find a reasonably priced battery on the ALCAN Hwy.
Have a great trip.
Old 04-27-2010, 01:01 PM   #4
1972 Travelux Princess 25
Cobourg , Ontario
Charge the batteries slowly, using a small charger, over a day or 2. They may come back. If not you need new ones.
A quick charge or high rate charge such as connecting to your tow vehicle may ruin them. Or, they may charge up OK. But the slow charge is the safest.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 04-27-2010, 01:17 PM   #5
wxbuoy's Avatar
Wildwood , Florida
Send a message via Skype™ to wxbuoy
Don't forget that your emergency break away system and electric jack are connected directly to the battery bar (where both batteries and the converter all meet). With out a good battery you don't have the emergency break away system. Also, you can't use the jack unless connected to 110 power.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 04-27-2010, 06:30 PM   #6
wxbuoy's Avatar
Wildwood , Florida
I have no idea how or why the word "battery" got posted in red! I wasn't trying to draw attention to it.
Dave and Felicia
Old 04-27-2010, 08:05 PM   #7
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
Be sure to sanitize the fresh water tank. Instructions are in your manual.
Set the water heater bypass valves so water will flow to the heater. Install the drain plug.
Close the low point water drain petcocks.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Getting Started alscottfree Member Introductions 3 03-12-2008 01:18 PM
Just getting started 406building4 Member Introductions 4 12-14-2007 10:08 PM
Getting Started pilgrim Member Introductions 4 09-18-2007 07:43 PM
Just getting started bawjr1 Member Introductions 2 07-28-2007 10:48 PM
Just getting started. Relentless Member Introductions 9 03-03-2007 10:16 PM
