Old 03-15-2009, 06:31 PM   #1
2002 25' Safari
Tallahassee , Florida
Getting on top of things (AS).
I've only had my Safari LS 25 since October and I need some advice. What is the best way to get on top of the AS to clean the roof, without damaging anything, dents, etc?
PassinThru is offline   Reply With Quote
Old 03-15-2009, 08:08 PM   #2
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Rib Walk
Hey, I get on top of mine occasionally to service/clean the air conditioner or to clean the top. The trick is to wear grippy shoes and walk gingerly only on the rivets because that is where the ribs are and strong enough to support your weight. Use great care--super slick when wet. Good luck.
Bill
Cantrell is offline   Reply With Quote
Old 03-15-2009, 08:11 PM   #3
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
After reading your post again, I think you may be asking how to get to the roof. I lean an 8 foot ladder against the awning housing and have someone stand at the base of the ladder for insurance.
Old 03-16-2009, 07:27 AM   #4
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I build ponds as my other hobby. I use a piece of rubber pond liner (or you can use a blanket etc...) and put it up against the side of the trailer and against the top so that the aluminum is protected from the ladder. Then, have someone hold the ladder and go on up.
Be careful and stay on the rivet lines. They are the strongest part of the roof. Stay off of the end caps....they will not support your weight and will dent easily. Go slowly and be aware of what you are doing the entire time. It's easy to do and you will build up your courage.
Have someone there when you want to come back down off of the roof. It's good to have the ladder held steady.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 03-16-2009, 10:42 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
For general cleaning, I simply get an extender car wash wand that has a sponge or cloth on it. With a ladder I can get all areas of the roof without having to go up there.
I recently got a scaffold that may help should I ever need to get up there, but so far I haven't and have accessed the roof for cleaning as I describe.
Old 03-16-2009, 11:08 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Stay on the ribs, off the end caps and good shoes.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-16-2009, 02:29 PM   #7
dstalzer's Avatar
2005 25' Classic
I just Walbernized my entire A/S except for the white painted roof. Do I need to Walbernize the roof also, and if so, is there a way to do that job without climbing on the roof?
dstalzer is offline   Reply With Quote
Old 03-16-2009, 02:43 PM   #8
Aluminut
2004 25' Safari
. , Illinois
I have a tall ladder where I get as much of the roof as I can without getting up on it. Now that I have a scaffold, I might be able to either get more or get up on the roof more easily. I try to stay off the roof as much as possible. Mine is stored indoors so it really doesn't see much game time outside to get enough nasty stuff that a wash so far has been able to remove.
To be honest, Walbernize is easy on, easy off, but it does not appear to last that long. I have tested some carnuba wax from Mother's that appears to last longer, but is more like car wax and a bit more involved in getting it off.
Old 03-16-2009, 02:48 PM   #9
dstalzer's Avatar
2005 25' Classic
Rivet
Thanks, mine is stored inside also and will be out maybe 3 to 4 weeks out the year for the next couple years. Then hopefully if the stock market recovers we will be out considerably more.
Old 03-17-2009, 09:03 AM   #10
2002 25' Safari
Thanks for all the replies, lots of useful information, I really appreciate it!
Happy Streaming!
Old 03-17-2009, 09:55 AM   #11
Aluminut
2004 25' Safari
. , Illinois
This post had me wondering, so I dug into my picture archives when I was at the factory.
I noticed something interesting in the wide body trailers. There is a rivet line on the curbside of the roof that is actually NOT on an alum rib.
If you are walking up on the roof, based on this pic I dug up, I would not walk on that rivet line furthest to the edge on the curbside. It would appear the street side and on either side of the A/C unit would be the best lines to follow. Check out the attached pics on the upper left areas and let me know what you think. On the rivet line in question you can clearly see the silkaflex sealant line the whole length of the trailer. These pics are two different wide body units and they both have the same curbside rivet line that does not appear to be under any rib.
This of course would not be an issue on the units smaller than 25' as they are not wide body and IIRC, have one sheet of alum for the roof, whereas the wide body trailers that start at 25' have the roof in two pieces riveted together.
ID:	77063   Click image for larger version
Old 03-20-2009, 09:41 AM   #12
2002 25' Safari
Silvertwinkie,
Great pics and VERY useful info on the roof. I concur with you analysis that there is a rivet line on the curbside that is unsupported. I really appreciate this update, as I would have used that rivet line to walk on, I'm sure.
Old 03-20-2009, 12:44 PM   #13
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Given all the stuff on the roof, walking may not be too common. Crawling and sitting are more likely. Fortunately this distributes weight over a wider area.
Trying to avoid getting on the roof, I haven't tried it. I would attach something to the ladder where it leans against the body, also looking for rivet lines. The awning wasn't designed to support a ladder and I would be very cautious about using that as a buffer though it's an interesting idea.
Certainly having someone on the ground is important. Having had a ladder fall over as I was about to use it and finding myself hanging by my hands from a roof 10' up from the ground, I can attest to the importance of having friends nearby. Not a lot of distance to fall, but the ladder was right below me and I couldn't have landed without getting my feet messed up in it.
Gene
Old 03-20-2009, 02:42 PM   #14
1987 32' Excella
Poplar Bluff , Missouri
As expensive as repairs are to the AS, I personally liked the picture I saw of a fellow who had scaffolding on one side, ladder on the other side, and a 2x12 stretch between over the top of his AS. He never got on top, just worked it from the plank... That's my plan when the time comes. As careful as I've been in the last 40 years while in various attics, I have still managed to run a leg thru a ceiling. Sure don't want to do that on my AS! LOLOL
Good luck!
Steven
StevenG is offline   Reply With Quote
Sneakinup will do great things with this Sovereign TomW 1974 - 1979 Sovereign 38 09-14-2015 03:59 PM
New Portable Camp Cook Top Mexray Stella's Kitchen 0 10-22-2011 06:27 PM
Things I learned, removing the Belly Plan from a 1963 Bambi Aktundra 1961 - 1963 Bambi 9 09-07-2011 10:11 PM
Carpeting 1967 step top? Stella Steps 2 07-04-2011 06:18 AM
