Old 12-13-2012, 01:53 PM   #1
1979 28' Airstream Excella 28
Albuquerque , New Mexico
Getting Into Gear
Just purchased a 1979 Airstream Excella motorhome. Is there a failsafe mechanism keeping the transmission from engaging such as the step being out or the door not being completely closed. Does the step operate on a separate battery from the starter. I can't seem to make it retract. Thanks for any advice. Alu-man. In need of some "alumanation" about this.
Alu-man is offline   Reply With Quote
Old 12-13-2012, 02:48 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'm not sure about your 79 but on my 82 the step is vacuum operated. It will not retract unless the engine is running and the door is closed. There is a button switch in the forward door jam that operates an electric solenoid valve the allows engine vacuum to retract the step. Check the vacuum tubing and operation of the solenoid valve. On my coach the valve is under/behind the step. That being said many have replaced the vacuum set-up with an electric operated step.
I hope this helps.
Cheers, Dan
Old 12-13-2012, 02:54 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Check the wiring at the steps, you may have a short, happened to us.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
