Old 11-08-2013, 08:18 PM   #1
beerob63's Avatar
1990 36' Land Yacht
San Antonio , Texas
Generator Operation
My generator acts like its going to start but doesn't. The shop that inspected the coach said it worked fine during the inspection (as does the former owners). Can anyone walk me through a routine start up? Thanks.
Bryan
beerob63 is offline   Reply With Quote
Old 11-09-2013, 08:00 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Bryan
My generator was doing the same. It would crank and crank and crank, but never seem to catch. The problem turned out to be a bad voltage regulator. In actuality, it would start, but then die on the very next stroke because as soon as the generator quit getting power from the batteries and started making its own power, the spark plug would get no power, and so the engine died.
Not saying that's your problem but it's a place to start.
Cats and ultraleather Airstream upholstery don't mix!
Old 11-09-2013, 08:33 AM   #3
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Choke might be stuck in the open position. Move the carburator linkage several times to set the choke.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 11-09-2013, 08:41 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
This might be somewhat simplistic, but have you checked to see that any valve to feed fuel to the generator is actually open? I realize that your genset runs on gas, but I had previously owned a LY diesel pusher that had a propane-powered genset. Often, when getting a propane fill, the valve for liquid propane to the genset would be shut at the tank.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
