Old 03-13-2009, 12:07 PM   #1
1976 25' Tradewind
Erie , Pennsylvania
Gaucho Sofas
I took my sofa's apart a long time ago to replace the flooring. It took me so long to fix the floor that I completely forgot how to put them back together. Does anyone out there have plans for how these babies go back together? I have 76 land yacht if that helps. Any help would be much appreciated.
rollingbubel is offline   Reply With Quote
Old 03-13-2009, 01:49 PM   #2
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
which parts?
Is your gaucho under the front window or along the side of the trailer? We have a '74 with the gaucho under the front window. If you let me know which parts are being a challenge to reassemble, I can see about taking some pictures.
Laird
maccamper is offline   Reply With Quote
Old 03-15-2009, 06:15 PM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I saw a post a few days back where there was a diagram of all the parts and how they assemble. Proably in the interior section of the restoration section. I just had a new gaucho made at a local upholstry shop. Took the old one in and they used it for a pattern for my 72 Tradewind
RichHog is offline   Reply With Quote
Old 03-15-2009, 06:20 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have an exploded diagram in my service manual. If you send me an address I can mail it to you.
Old 03-15-2009, 08:09 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Guide to the Gaucho
Restoration Topics - Sofa Beds
Old 04-03-2009, 10:08 AM   #6
1971 31' Sovereign
Bear Lake , Michigan
I am in the process of putting in an orininal gaucho in my '71 Soverign and am having issues on how the front two struts attach to the front wall??? If you could please send me your view, i woulld really appreciate it as it looks like I am missing some sort of bracket that joins the two?? Thanks....John
whprt65 is offline   Reply With Quote
Old 04-03-2009, 02:15 PM   #7
1976 25' Tradewind
Erie , Pennsylvania
Thanks to all!!!! After a long and tedious trial and error I figured it out. Make sure you like up your guacho parts with the pre drilled holes of the metal arms.
Old 04-03-2009, 02:17 PM   #8
1976 25' Tradewind
Erie , Pennsylvania
I had a wooden bracket that fit around the electrical box. The bracket screwed right into the wall. From that point I was able to screw the guacho frame to the bracket. I hope this helps.
1989 gaucho questions crispyboy General Interior Topics 4 05-14-2011 06:45 AM
Minuet streetside gaucho problems MyHappyPill All Argosy Trailers 10 03-18-2011 06:34 PM
Placement of lower curtain tracks over back gaucho 73 Tradewind. constructor Upholstery, Blinds, Walls & Interior Finishes 1 03-17-2011 06:22 AM
What is a gaucho? Michigander Interior Restoration Forum 8 02-21-2011 08:20 PM
Overlander Gaucho pics NicheVintage 1965 Overlander 11 01-28-2011 12:12 PM
