Old 08-02-2012, 07:48 PM   #1
1998 31' Land Yacht
AURORA , Colorado
Gas Gage
I have a 1998 Land Yact and the gas gage only works half way. It tells me I am empty and I can only get 40 or 42 gallons in the tank. What is the fix?
Big Denny is offline   Reply With Quote
Old 08-13-2012, 01:02 PM   #2
1977 28' Argosy 28
Columbus , Ohio
Gas Gauge
It sounds like a problem with either the float, the sending unit, or the gauge itself... Possibly all three components.
If the unit has "sat still" for long periods, the gasoline in the tank can 'gum up' and wreak havoc on the float and sending unit.
The electric gauge in the dash is just that... eeee-lectrical... meaning you never know when something like it is gonna go deep six. It's possible that it's getting shorted by another wire up underneath the dash... have you looked back there?
An even scarier idea is.... the oil companies keep adding "great chemicals" to make us believe that we're getting some kind of whiz bang deal, better mileage, cleaner-burning fuel, etc... but what it comes down to is, is that sometimes those chemicals play heck with plastic and metal that the floats/sending units are made of.... I've even seen tank-internal fuel pumps go bad because of lousy gasoline.
The bright side (hopefully) is that if you buy gas from the same outfit ALL THE TIME (and can prove it through reciepts) that company will usually cover the cost of repair (if the failure was due to their product)
Good luck in your getting to the bottom of that problem! Keep us posted on any developments!
CHEERS!
Slick and Kathy
Columbus, OH
slickandrews is offline   Reply With Quote
Old 08-13-2012, 01:19 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
From a full tank, if you know your typical fuel mileage, you can use the trip odometer to estimate how much range you've got, ignoring the malfunctioning fuel gauge. Just reset the trip odometer to zero every time you fill up, and completely fill up every time you stop for fuel. I did this for a while with my old pickup truck until I could get the sending unit replaced. Use your worst estimated mileage, and allow about 100 miles of range as a buffer to prevent running completely out.
To replace the sending unit, you may have to drop the tank and remove the sending unit (which might be incorporated into the fuel pump as a single unit). Replacing the sending unit with a new one is probably the most reliable fix, versus trying to troubleshoot and repair the old one.
Best to do this when the tank is as empty as you can reasonably get it. Gasoline weighs a little over 6 pounds per gallon (so does diesel), so dropping and reinstalling the tank goes better with a nearly empty tank.
Also, while you've got the tank removed, completely clean it to remove any built-up sediment or chemical goop. By the way, you're likely to have goop in your tank if you've mixed ethanol fuel with non-ethanol fuel and then let it sit for a while. Seems that ethanol doesn't play well with the additives it's supposed to replace.
also, it makes a difference what type of material the tank is made from. Ethanol also doesn't like fiberglass (it acts as a solvent for the fiberglass resin), so if you've got a fiberglass tank, you might be looking at a complete tank replacement. For metal tanks, monel is best. For plastic tanks, ABS plastic.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-13-2012, 05:20 PM   #4
1988 32' Excella
Robbinsville , New Jersey
Sometimes using some carburetor/fuel injection cleaner in the tank can cleanup the sending unit and get it working again.
