Old 05-29-2014, 01:37 PM   #1
Ventura , California
Galley Hand Pump
Hi All--Wondering if you can give me some insight into how to go about fixing my galley handpump. It is the original in a 58 Airsteam Traveler. Pump is fine but does not draw any water. It use to if I sucked the water to get started but now that does not work. Looks like it needs some type of gasket repair or something?
Any help would be appreciated.
Bart
bartb is offline   Reply With Quote
Old 05-29-2014, 01:45 PM   #2
MYater's Avatar
1948 22' Liner
Roy , Utah
Send a message via AIM to MYater Send a message via Yahoo to MYater Send a message via Skype™ to MYater
At least I am not alone on this problem. However, I don't have to worry about it for another year since I haven't gotten to the point of putting the inner skins back on.
But yes you are probably going to have to disassemble the hand pump and replace the O-rings and perhaps any gaskets as well. Unless you find something solid is broken inside the pump, a quick trip to the hardware store should help you fix any O-ring issues.
"Some things you can tap. Some things you can hit. Know which one is which!"
1948 Airstream Liner 22'
MYater is offline   Reply With Quote
Old 05-29-2014, 03:16 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
There are also modern replacements available if the existing one can't be repaired.
Rocker Hand Pump
Attwood Dual Action Pump Faucet
Old 05-30-2014, 11:46 AM   #4
Hand Pump
Thanks guys--really appreciate the help. Hardware store bound for o rings
Hand pump faucet Apache_Camp Sinks, Showers & Toilets 1 04-19-2010 05:49 AM
Vintage Hand Pump Faucet Trouble tpezzolo Sinks, Showers & Toilets 3 03-31-2009 07:16 AM
Hand Pump Water Faucet - How to Test? tpezzolo General Repair Forum 0 03-30-2009 02:09 PM
Galley hand pump conversion to electric? cuyeda Water Heaters, Filters & Pumps 2 02-06-2007 05:47 AM
Sink Hand Pump Repair Gene Dallago Water Heaters, Filters & Pumps 4 10-23-2002 09:21 PM
