Old 06-06-2016, 11:55 AM   #1
1981 31' Excella Limited
Ojai , California
Furnace screaming at me
I have a 1981 Excella 31. I've done some restoration work on it, but recently have noticed that when the furnace turns on it begins a high-pitched scream. I've tried shooting some light oil on the area around where the bearings hold the squirrel cage fan in the furnace, but cannot get very close to these bearings to apply heavier oil on the exact bearing races. I can't see any easy way to extract the furnace to do these repairs. I believe the furnace is stock and as it would have come on this AS when it was new. Anybody out there smarter than me on this?
Lee Prather is offline   Reply With Quote
Old 06-10-2016, 11:11 AM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Having removed and replaced the furnace in a '78, I will second the notion that there is no easy way to do it.
It took me about 2-1/2 hours each way for taking the old one out and putting the new one in.
Old 06-10-2016, 02:22 PM   #3
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
I'm going to chime in here so I can follow this conversation as my '01 furnace is doing the same thing. Lucky for me, it looks like it'll be easier to remove than the '78....
I'm guessing if the fan motor bearings are "screaming" that a replacement motor is in order?
( as in.... NOT repairable? )
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 06-10-2016, 02:36 PM   #4
drboyd's Avatar
1978 25' Tradewind
It would be theoretically possible to get some more life out of the motor by oiling it, but it wouldn't be likely to give you as long a life as a new motor.
But who knows what kind of quality you'd get in a new motor, so there's that.
Old 06-10-2016, 02:36 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I replaced fan motor.. Simple.. And about $60
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-10-2016, 02:40 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is one example.. http://m.ebay.com/itm/Atwood-37697-H...830?nav=SEARCH
Channing
WBCCI# 30676
The Screaming Flamingo :: 1963 Airstream Overlander soldiermedic Airstream Registry Discussions 0 09-30-2012 06:58 PM
Screaming Flamingo Hot Sauce soldiermedic Stella's Kitchen 13 07-25-2012 04:30 PM
I want to die in my sleep like grandpa, not screaming like everyone else in the car roadtrip232 On The Road... 4 03-28-2012 08:36 AM
Route 66 is Screaming for Me... !! Need Advice! LittleRadio Our Community 18 05-14-2003 01:52 PM
