Old 11-08-2014, 02:54 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Furnace repairs
Does anyone know where I can get the Suburban furnace repaired out of my '76? I'm just outside Kingston NY. About 100mi. North of NY City, on the Hudson River.
Hunter
Stone Ridge is offline   Reply With Quote
Old 11-08-2014, 03:05 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Hunter
I just checked the manufacturer's web site and this is the closest repair facility they listed:
Classic RV Repairs & Restoration
5 Sybil Court Suite B
Holmes NY, 12531
845-319-6007
Here is another closer to Albany:
Happy Kamper Mobile RV Repair
2059 State Route 95
Schodack Landing NY, 12156
518-755-0037
Good luck!
Bob Martel
WBCCI# 5766
Old 11-08-2014, 03:25 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Hunter
You're NOT going top like this, but a 38 year old furnace should be SCRAPPED AND NOT REPAIRED !! It really doesn't matter what type of repair is needed. Old furnaces have a very high potential to either leak LP or carbon monoxide into the trailer due to internal corrosion and/or parts break downs.
This is exactly what I would tell to a potential customer in the same situation. I would be very surprised if you can even find anyone who wants to accept the responsibility (read LIABILITY) of working on a furnace that old.
Sorry, but that is my professional opinion..... Just what DO you consider your life worth???
Old 11-08-2014, 04:10 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The furnace on out '83 needed repair. When I started into it I came across a bunch of rusted screws and other parts. I figured the rest of the unit could not be far behind so got a new one. Works great with no worries.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-08-2014, 09:28 PM   #5
1976 31' Sovereign
1963 16' Bambi
Thanks for your comments. I purchased the furnace new 4 years ago and have had it repaired three times. I use the 31' as a woodshop and apparently the wood dust fouls things up. When I get this fixed I'll put it in the 21' which has no furnace in it now.
Hunter
Old 11-09-2014, 07:44 AM   #6
lewster's Avatar
Hunter
AHHHHH! The plot thickens!!
That is a completely different scenario! Yes. the wood dust coming back thru the intake will definitely lodge in the blower cage and foul up the works. You might consider using a pre-filter Like those used on residential air conditioner systems on the intake plenum after you have it cleaned and repaired and change it often.
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 06:28 PM
1978 AS Sovereign and doing my own repairs JLD Our Community 2 09-05-2002 11:28 AM
Post rally mechanical repairs PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 16 07-10-2002 04:36 PM
Transmission repairs rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 08:51 AM
