Old 04-18-2019, 05:44 PM   #1
2019 23' International
Loda , Illinois
Furnace Help
My furnace will fire up just fine and heat the trailer to the desired temperature, BUT, it will not cycle back on as the temperature goes down. It has a brand new Dometic Comfort Control and all else appears fine. Does anyone have any suggestions? Thanks
Cdusm is offline   Reply With Quote
Old 04-18-2019, 05:50 PM   #2
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
I think there is a reset on the thermostat. I think your Airstream's instruction manual or the thermostat's instruction manual will walk you through the reset function. I've never had this problem so I'm not sure the reset will fix your problem, but I can't imagine that it would hurt anything to try the reset.
I believe this is the instruction manual for your thermostat. At the end of page 3 and beginning of page 4 it describes how to do a reset. Then it says to go to page 19 where a reset appears to be better explained. https://www.dometic.com/assets/59/19...9.pdf?att=true
SYSTEM RESET PROCEDURE:
When your unit was installed the appropriate dip switches on the electronic control board were turned ON to match your system configuration. Any time these settings are changed, a system reset will need to be done before the CCC 2 thermostat will recognize the updated selection.
To do a system reset:
1. Make sure the CCC 2 thermostat is in the OFF mode.
2. Simultaneously press the MODE and ZONE buttons. The LCD will display “IniT” and all available zones.
3. Release the MODE and ZONE buttons.
4. Press the ON/OFF button to exit system set up.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-18-2019, 07:54 PM   #3
Loda , Illinois
Thanks! I will try it tomorrow. Seems like it should be. Something simple.
Old 04-18-2019, 10:25 PM   #4
CruizinDux's Avatar
Tracktown USA , Oregon
IMO the hard boot reset fixes a lot of setting quirks and otherwise of the ccc2.
You might to a search re ccc2 as there is a very good thread on this subject. I'll try to find and post.
As an example if while the unit is running ( i suspect mode is academic) if you change fan speed from auto to slow,(or probably high as well) then turn the unit off, the ccc2 becomes very confused.
In my case, when i did the above inadvertently when using the furnace, then turned it off. The next day when i turned on the furnace, the A/C would simultaneously fire.
ccc2 hard boot reset solved the problem.
CruizinDux is offline   Reply With Quote
Old 04-18-2019, 10:36 PM   #5
CruizinDux's Avatar
Here ya go...
http://www.airforums.com/forums/f287...al-188534.html
Good luck.
Old 04-19-2019, 02:21 PM   #6
Loda , Illinois
Thanks to you both. Before I could do anything, furnace is working fine and cycling properly. I'll have to wait to see if it does it again. I appreciate the advice.
Dave
Old 04-22-2019, 03:26 PM   #7
AirMiles's Avatar
Dave
This is similar to what happened to me last year when dodging a hurricane. My A/C would not turn on as the temperature was stuck on 99 degrees. We spent a hot night in Tallahassee with no A/C. The next day I bought a new thermostat at Camping World on my way to Dothan AL. When I stopped for the night, my old thermostat was working perfectly. It never had this problem again and I'm sure it won't now that I have a backup!
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
