Old 03-30-2014, 10:25 AM   #1
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Furnace/Heat Pump question
Ok boys and girls, get ready for some amusing newbie type questions regarding the interior heating system. When I set the Dometic controller to Furnace, the unit in the ceiling comes on and begins to blow cool air, and warm air begins to emerge from the floor-level vents. Eventually warm air flows from the ceiling unit too.
I know that the ceiling unit is the air conditioner, and I assume it is also the heat pump and perhaps the fan system for the furnace. The ceiling unit is noisy, kind of objectionably noisy.
The very brief Dometic manual doesn't tell me much. I wish it explained more about the relationship between the furnace and the ceiling unit (and it's functions). Perhaps someone would be kind enough to give a brief rundown of how the system works.
Here are the main questions I have:
Is the ceiling unit always on when the furnace runs?
Is there any way to turn the ceiling unit off when the furnace is running?
Thanks!
brad1 is offline   Reply With Quote
Old 03-30-2014, 12:53 PM   #2
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We have a 30' International. On ours the heat pump and the furnace work independently of each other. The ceiling unit is the A/C or heat and the furnace is just heat.
I can agree 100% on the heat pump being way too loud.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 03-30-2014, 12:55 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You probably have the CCC2 thermostat. If, while selected to FURN, you have the fanspeed selected to anything other than auto, then the roof unit fan will run to circulate air. In Auto, the fan will stay off and only the furnace fan will run.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-07-2014, 09:24 AM   #4
Aptos , California
I know this is awfully late, but Larry, thanks for the reply. You saved my butt from freezing one surprise snowy morning after an overnight stop at Shasta City.
Old 08-07-2014, 09:24 AM   #5
Aptos , California
Wait, I meant Ibrosky
Old 08-07-2014, 10:25 AM   #6
lsbrodsky's Avatar
It is Larry
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
Trouble shooting Furnace/Heat Pump/Air C? Kistler Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-07-2007 12:13 AM
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 03:10 PM
