Old 04-26-2014, 08:57 PM   #1
1979 24' Airstream Excella 24
Woodland Hills , California
Fuel pump problem
I have a 1979 Airstream 240. 454 v8, gas engine motorhome.
I'm pretty sure the existing electric fuel pump is itermitent and bad.
I don't know what pump pressure rating is needed for this motorhome.
If I went to Pep Boys and asked for and asked for a 79 Chevy P-30 454 v8 compatible electric fuel pump, would they know what I need?
I don't think so, and That is why I am reaching out to the
Airstream community. Does anybody know the best brand? Pressure needed?
etc.
I know the motorhomes came with mechanical pumps, but since the unit has been retrofitted with an electric pump, I think I want to keep it electric.
If I replace it with the same electric pump, I'm left wondering if it is under pressured or over pressured?
Any help would greatly be appreciated.
flatouf is offline   Reply With Quote
Old 04-26-2014, 09:11 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Fuel pump problem
You will need a low pressure fuel pump or a regulator to keep the pressure below 7psi. I recommend a CARTER pump, P4070.
You will not be disappointed in its performance or its longevity.
Old 04-26-2014, 09:33 PM   #3
Morgan,
Many thanks for the info.
I'm on it! and hopefully rollin again!
Old 04-26-2014, 09:59 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Good luck with everything, and take care !
Electric fuel pump problem flatouf Classic Motorhomes 13 05-04-2014 12:36 AM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 04:35 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
