07-15-2018, 01:40 PM
Santa Rosa
Front window strap repair
NOTE: This is my first tutorial post. It's taken me a while to learn how to get photos to attach. If I can figure out how to get the photos to attach directly (instead of links), I'll come back and modify.
We've had our 2018 Flying Cloud for about a year now. It seems to me that it will only be a matter of time before one or both of the two rubber things that secure the front plexiglass window protector, will break. I decided that I'd rather be ready now, than have to problem solve on the road. This is a preemptive repair.
If you do this, WEAR SAFETY GOGGLES and whatever other protection you may need.
Because the rubber part that is likely to break has been riveted to its steel bracket, fixing this on the road seems like it would be difficult.
https://i.imgur.com/4CujJ5Q.jpg
After buying the replacement part, I took a dremel to the side of the rivet that has a "rim". This side requires less grinding than the other side, which is nicely domed.
https://i.imgur.com/gXn7dCp.jpg
After grinding the "rim" of the rivet off, the rubber part can be removed from its steel bracket.
https://i.imgur.com/buXFcFr.jpg
Then the same thing was done to both of the ones on the Airstream. Tape protects the finish from damage from the grinding.
https://i.imgur.com/XV3ozOy.jpg
6/32 X 1 1/4 Stainless steel Allen-head bolts and stainless nylock nuts were selected to replace the rivets. The bolts were a little longer than needed, so I trimmed them down.
https://i.imgur.com/mMPDVab.jpg
Now the Rubber hold-downs are secured in a way that I can replace them whenever they break.
https://i.imgur.com/HOQR0WD.jpg
And here's the repair kit that I keep in a baggie in the toolbox. If you look closely, you can see that I applied epoxy to the threads where they contact the rubber, to reduce wear.
https://i.imgur.com/8rXHpnW.jpg
--Sean
07-15-2018, 02:24 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Thanks for sharing!
Alan
07-15-2018, 02:40 PM
Kensington
, Maryland
07-15-2018, 02:41 PM
Kensington
, Maryland
Well done sir
07-15-2018, 03:18 PM
2016 30' Classic
Houston
A very good post - was just thinking the same as I put sone UV protectant on front plexiglass window's rubber straps. After 2 years, they seem to be in good shape - no evidence of cracking. That said, I will order a spare or two and put them in the tool kit.
07-15-2018, 04:00 PM
1994 30' Excella
Mississauga
, Ontario
Mine are now 24 years old and still ok.
Al
Al and Jean
TAC ON-3
07-16-2018, 08:27 AM
Santa Rosa
Thanks for the compliments. Hopefully most of you will get good life from yours like Big Al, 24 years is a great run for a rubber part! When I bought the replacements, the dealer (Bay Area Airstream) said they replace about two per month for people. Mine are a year old and already getting a little chewed up where they rub past the part on the window cover.
--Sean
07-16-2018, 09:33 AM
1969 18' Caravel
Greenville
, whereEverIroam
I have a 1969 that I acquired around 2004, give or take. AFAIK the rubber hold downs on the front window guard are original and still work fine, so far.
Perhaps they are due. They have outlasted the original AC, water pump, running lights, scare light, furnace, toilet, overhead fan, door latch, plastic cabinet latches, and several of the 1/4" plywood interior walls.
You would think with that much UV exposure, they would have deteriorated by now, but the rubber is still soft and pliable.
07-16-2018, 03:38 PM
2016 28' International
Sioux Falls
, SD
--Sean
My EXACT issue and was going that route!
Thanks for posting, I don’t have a Dremel but will come up with something.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
07-16-2018, 04:03 PM
Santa Rosa
DBinSD, you can drill out rivets, also from the rim side. The replacements would probably be pretty easy to drill, but the ones on the trailer may be difficult because of how close they are to the trailer shell. It may be a real challenge to get the drill close enough without causing costly damage. You might consider purchasing a Dremel or something very similar, you may be surprised at how inexpensive a starter kit is. It'd be a sickening feeling to have the drill slip, and punch a hole through the front of your Airstream.
--Sean
07-16-2018, 07:03 PM
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg
~snip...
--Sean
To add photo instead of linking, click the paperclip next to the smiley face and then select the files you want to upload.
07-17-2018, 11:58 AM
Santa Rosa
RJJ thank you, I'll try that out
--Sean
07-19-2018, 04:01 PM
1975 27' Overlander
Galena
1975 vs 2018
I had to replace my front window tinted protector in an insurance claim last year. It came with 2 brand new rubber tie down handles but I didn't change them only the large glass and frame. It appears my 1975 rubber tie downs are still going strong. However, I do now own 2 extra ones in case they break before I die of old age. Whats funny is that my 1975 rubber tie downs are the same as 2018 tie downs. I guess it is made to last so why change the design.
