Old 10-02-2012, 02:21 PM   #1
quoyle's Avatar
2010 19' Flying Cloud
1969 21' Globetrotter
Bradford , Vermont
Front motorized jack on 2010 Flying Cloud just stopped
I'm buying a 2010 19-ft. Flying Cloud, planning to pick it up tomorrow. Was testing the hook up to my car, the Barker Hi-Jack 3000 worked perfectly; I raised the tongue of the Airstream, backed the car up, lowered it onto the ball; then it just stopped running. So the airstream was stuck on my ball, and I couldn't get it up. Actually had to use my car jack to get it off the ball.
Any idea what may be wrong with it? I want to pick up the Airstream, but now am stuck.
quoyle is offline   Reply With Quote
Old 10-02-2012, 02:24 PM   #2
2010 27' FB Classic
N/A , Texas
If it was not hooked up to your tow vehicles electric then the first thing I'd check is the batteries in the trailer. Sounds like you ran out of juice.
Old 10-02-2012, 02:29 PM   #3
dznf0g's Avatar
Oswego , Illinois
Other than the flat batt, there is either an inline fuse for the jack (which I think is the case on a FC) or a breaker in the 12V "fuse" panel which could be blown/tripped. The other thing to check if a fuse/breaker issue is a potential pinch point for the power supply to the jack at the aluminum LP bottle cover (again if a FC has one) right at the jack post base.
-Rich-
Old 10-02-2012, 06:48 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I believe there should be a manual crank as well just for such occasions.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-02-2012, 07:43 PM   #5
quoyle's Avatar
Bradford , Vermont
Thing is, it was hooked up to the tow vehicle when it stopped running. I'm sure the batteries in the AS are dead (it hasn't been used in 6 months), but I thought the power from the tow vehicle would run the jack even with dead AS batteries.
Old 10-02-2012, 08:02 PM   #6
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
Can you hook it up to shore power?
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 10-02-2012, 08:09 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
There is a fuse in the wire between the battery and the jack...it's near the tongue street side below the propane tank area (on our 06 19') . Out jack suddenly stopped once; the fuse holder had come apart and the fuse fell out on the ground, so the jack wouldn't work. Put the fuse back in and all was well. I'd check that first.
To prevent wiring from wearing through and shorting from the bottom edge of the propane tank cover rubbing against it, I got a piece of clear plastic tubing, sliced it open lengthwise and slid it over the wiring, securing the tubing in a few places with black electrical tape. I didn't wrap it completely with tape so that it would not hold water.
I am not so sure the jack will work off the tow vehicle's battery if the trailer battery is compromised.
TB & Greg and Abbey Schnauzer
#3954
Old 10-04-2012, 07:39 PM   #8
quoyle's Avatar
Bradford , Vermont
Thanks everyone for all the help with this. After charging the battery with shore power, the jack worked fine.
