Old 11-21-2015, 04:44 PM   #1
1990 32' Excella
Midland , Texas
Fridge Not Lighting on LP
My fridge LP operation worked well and then I lit the hot water heater and oven and it started kicking off the LP for the fridge and only operating on electric. Not a prob while at RV park, however I couldn't run LP while driving home (thus requiring me to buy one of those squeaky styro coolers and bags of ice). Plenty of LP in tanks. When I go thru the on/off switch reset I can hear some slight clicks (probably an igniter?). Any ideas?
DWade is offline   Reply With Quote
Old 11-22-2015, 07:16 AM   #2
2011 23' Flying Cloud
Durango , Colorado
I had a similar issue after 40,000 miles of travel with our FC23FB. The RV mechanic cleaned out dirt and debris in the fridge burner chimney. Problem solved.
Safe Travels,
Jamu Joe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-22-2015, 09:17 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If your tank regulator is working there is no reason that the use of the stove and or hot water heater should effect the frig.
crack the gas line at the frig until you smell gas to prove that air is not in the line. Close the line and retry.
2004 Excursion 4x4
Old 11-22-2015, 09:52 AM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Sounds like you need to check the pressure. Fortunately, my fridge has a gauge in the gas line for just that.
CRH is offline   Reply With Quote
Old 11-22-2015, 10:06 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I had a problem where if I used my gas grill and stove while the water heater was running it would shut off. This was just before my changeover valve failed. Replaced changeover valve and regulator as a unit and the problem went away. I suspect the regulator pressure was down.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-22-2015, 10:39 AM   #6
2018 25' Flying Cloud
Mission , Texas
We had a similar problem...frig would run on gas for a few minutes the red light flashed. Had to get a new 'mother' board installed ($250)! Ouch!
ghamr is offline   Reply With Quote
Old 11-22-2015, 10:51 AM   #7
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
We had this problem. First check to see if pilot light is burning. If it is - turn off gas. Remove the gas jet and soak it in denatured alcohol. Blow it out with compressed air. Clean burner tube with small bristle brush or pipe cleaners. This fixed our problem.
KenSanLan is offline   Reply With Quote
Old 11-22-2015, 11:36 AM   #8
1998 30' Excella 1000
Livingston , Texas
Safe Travels,
Jamu Joe
I've seen the routine maintenance instructions recommending to clean the burner flue, but always wondered how it was done. There is a "baffle" in the flue that would make it difficult to run a brush from the bottom up through the top. And you can't access the whole tube on my rig without pulling the refer almost completely out of it's cabinet. Maybe your tech blew it out with compressed air?
Siegmann is offline   Reply With Quote
Old 11-22-2015, 12:49 PM   #9
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Sounds like it may be a bad regulator. Try running your over, furnace and stove top all at the same time. If they wont all run then my guess is bad regulator.
mayco is offline   Reply With Quote
Old 11-22-2015, 02:27 PM   #10
1996 25' Excella
Tillsonburg , Ontario
Typically the burner Flue is blown out with compressed air. Messy job. Then you need to disassemble the burner and blow all the rust particles out of it. One thing I found some years ago was the rust from the flue had fallen on the burner which is just a closed end tube with little slots in it. Gas could not get out the slots and thus no flame. Quick blow with air fixed the problem, but brushing it off would help. You need to remove the wind baffle ( cover around the flame) to get at it. About 3 screws as I remember.
JCW
JCWDCW is offline   Reply With Quote
Old 11-22-2015, 03:05 PM   #11
Livingston , Texas
Like I thought, compressed air. Thanks for confirming.
Old 11-22-2015, 03:25 PM   #12
I wondered the same thing when I tried to clean mine. Do you blow the compressed air in from the bottom, top, or both?
Al
S/OS #004
Old 11-22-2015, 03:47 PM   #13
Livingston , Texas
If you have a full height fridge, like I do, you probably can not access the top of the flue without pulling the fridge out, which requires a significant effort. I'd blow from the bottom.
Old 11-23-2015, 06:50 AM   #14
1996 25' Excella
Agree... you cant get at the top. Remove shroud, cover the burner and blow straight up. There are coils of gas and electric heaters in there so don't be poking around in there!
JCW
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
Dometic Fridge not lighting w/Propane zimode Refrigerators 9 09-21-2009 07:08 AM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 02:03 PM
Lighting pilots and testing fridge and furnace sp635 General Repair Forum 3 11-02-2007 01:10 PM
