Old 11-24-2015, 08:19 PM   #15
2011 23' Flying Cloud
Durango , Colorado
Originally Posted by Siegmann View Post
I've seen the routine maintenance instructions recommending to clean the burner flue, but always wondered how it was done. There is a "baffle" in the flue that would make it difficult to run a brush from the bottom up through the top. And you can't access the whole tube on my rig without pulling the refer almost completely out of it's cabinet. Maybe your tech blew it out with compressed air?
Actually, he was a mobile mechanic who came to my storage lot. He did a quick flue disassembly and brushing without compressed air. Some rust, some red dirt from boondocking in Utah. I thought that $40 for a 'house call' repair was quite a bargain!
Safe Travels,
Jamu Joe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-24-2015, 09:30 PM   #16
1998 30' Excella 1000
Livingston , Texas
I thought the 23' units had full height refers. On my unit, it has an inaccessible flue top. Yours must be different?
Siegmann is offline   Reply With Quote
Old 11-26-2015, 09:06 AM   #17
Durango , Colorado
Our flue is accessible behind the lower of the two louvered vents on the port side.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
Old 11-26-2015, 10:22 AM   #18
Livingston , Texas
Yup, definitely different. I only have a lower louvered vent, and then a roof top "scoop" covered vent. I can only access the bottom of the flue.
Old 12-01-2015, 06:34 AM   #19
sroach's Avatar
2012 23' FB International
Warrington , Pennsylvania
Originally Posted by DWade View Post
My fridge LP operation worked well and then I lit the hot water heater and oven and it started kicking off the LP for the fridge and only operating on electric. Not a prob while at RV park, however I couldn't run LP while driving home (thus requiring me to buy one of those squeaky styro coolers and bags of ice). Plenty of LP in tanks. When I go thru the on/off switch reset I can hear some slight clicks (probably an igniter?). Any ideas?
Probably a simple and easy fix. Same thing happened to me about a month ago..
Take off the over to the ignitor for our burner. You'll have a tip on one end and a burn tube on the other. clean out the tube and remove the tip and make sure that is clean and clog free.
as you're putting everything back together make sure the thermo-couple is touching the flame.
sroach is offline   Reply With Quote
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
Dometic Fridge not lighting w/Propane zimode Refrigerators 9 09-21-2009 07:08 AM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 02:03 PM
Lighting pilots and testing fridge and furnace sp635 General Repair Forum 3 11-02-2007 01:10 PM
